I am slowly making my steps to build a proper infrastructure to then be able to make the most of the Smart home world.
I have already succeeded to install HA on a VM on a DS720+. Everything worked as expected. Went through a reverse proxy with associated DNS and certificate for external access, all good.
But this was all on one LAN network.
After quite a bit of reading I am convinced of the benefits of the VLAN management approach.
Plan is 3 VLANs for now:
HA goes on the IoT obviously.
I can connect locally via browser when I am on the IoT Vlan, so I know it is running properly.
The issue is about external access, I try to use the same strategy as when everything was on the same network but it seem that when the NAS does the portforwarding rule to the routeur, it does it to the NAS IP address and not the VM
If I try to log, I get a synology message that the page can’t be found.
As an additional check, if I move the VM to the main/primary network and reconfigure accordingly I can access it from outside.
Thanks!
