I tried to update my installation by renaming the working homeassistant venv and make a new one:
pip install virtualenv
cd ~/
python3 -m venv homeassistant
source homeassistant/bin/activate
pip3 install homeassistant
I made a backup so I could easily go back, but I need to know why it failed.
The new installation was very slow and PyNaCl was missing for the Mobile App component. The configuration check took a long time, restart failed.
What could have gone wrong? Did I miss some dependencies? Shouldn’t home assistant install all components?
Tinkerer
(aka DubhAd on GitHub)
March 10, 2022, 7:41pm
2
What version of Python were you using for that? It should have been 3.9.
3.9.10 was installed on the Mac.
Tinkerer
March 10, 2022, 8:40pm
4
Then, possible reasons could include that it’s compiling modules. The log file should contain some hints, but checking the process list will give you other information.
This stays for a long time.
Wrapping up startup, not everything will be available until it is finished.
Then I get this when checking the config:
Integration error: default_config - Requirements for mobile_app not found: ['PyNaCl==1.4.0'].
Installed is version 1.5.0, if I downgrade it, it works and is much quicker.
pip install PyNaCl==1.4.0
So this is a bug in homeassistant installation 2022.3.3?
Tinkerer
March 11, 2022, 9:04am
6
What custom components are you using? One of them is specifying PyNaCL 1.5.0 - HA requires 1.4.0 .
That makes sense. How can I find out what custom_components install?
It was config-editor. I deleted it.
Thanks for your help
I have this error again. How can I find the component making the issue?
Must be another one as well.
Tinkerer
March 13, 2022, 11:53am
9
Check the manifest.json
for all your custom components, then open an issue with the developer.
There are none under requirement nor dependencies.
I had one, but I removed it.
How do you uninstall a custom_component manually? Just removing the folder or is it more? Where are their setting saved?
Btw. is it safe to remove ~/.homeassistant/.storage/HACS I don’t have it anymore (I also just deleted the folder in custom components).
Tinkerer
March 13, 2022, 12:53pm
11
To remove a custom component:
Remove the integration (through the UI or YAML as appropriate)
Restart HA
Delete the folder
Yes, you can remove that file.
Let’s say, I didn’t do the first step.
How can I fix that?
Tinkerer
March 13, 2022, 1:14pm
13
Well, if it’s YAML then you can just remove the YAML and go.
if it’s UI setup though, you’ll need to reinstall the component.
I tried out a lot in the beginning. Where can I find what was/is installed?
Tinkerer
March 13, 2022, 1:43pm
15
Check your log file for errors, see what it’s complaining about - if anything.
There is nothing showing up.
Tinkerer
March 13, 2022, 2:01pm
17
If there’s no errors or warnings then you have nothing to worry about.
