Installation with balena etcher does not work properly, cant reach it even with IP-adress
Hello, I´m quite new here and need your help, please.
I´ve installed homeassistant as shown in the manual. but when i put the sd-card to my raspberry pi 400 (Py 4 isn´t available) and connected it to the router, i can see the py in the router listet connections, also the IP but when i try to reach the py via homeassistant.local:8123 or via IP:8123 the ystem returns, the site is not available.
Thanks for your help
Sincerly Frank Düring from Germany
Do you know the Py 4 IP address?
If so then try XX.XX.XX.XX:8123 or another example would be 192.168.1.1:8123
Depending on your router setup the .local doesn’t always work.
