Installed 86.2
…and I have configuration errors.
Did I miss the link to where all the changes are that I need to make to my configuration.yaml file after the conversion?
Can anyone point me in the right direction, because apparently I have a lot of work to do and do not know where to start without the documentation.
Thanks!
There have been loads of post over last couple of days regarding these and most have the solutions in them
Start with the release notes!
entity id’s have changed…
remove double _'s and replace with single
look at the errors for invalid id’s
remove leading or trailing _'s from id’s
check automations for changes to time in triggers
check groups, automations and customize files for all the above
don’t forget packages
OK, so no page I missed with XXX no longer valid. etc.
Thanks.
apart from the release notes that spell it out you mean?
Only what’s on the release notes for breaking changes
OK, thanks
