Installed HA on Synology DS220+ NAS using Docker, can't log into HA
I can’t seem to log into my new install of HA. I used the IP of the synology:8123 and I get refused connection. Any ideas on how to get HA to launch? thanks
Is HA running?
Share your docker run command or docker compose file, or screenshots how you set up the container. Are you using host networking or port mapping? Do you have the firewall enabled on the NAS?
