tellblom
(Tellblom)
1
Installed following this manual https://custom-components.github.io/hacs/installation/manual/ on my Hass.io 0.97.2. Running on a RPi 3B+
When I press the Community Menu I only get a spinning “dougnut” and it won’t stop at all.
What I can see there is no error messages, nothing
Any ideas what could be wrong?
jimz011
(Jim)
3
You should restart before entering any config (at least that is what the docs say). So in this order:
- download/install HACS
- add hacs to configuration.yaml (no config just hacs)
- restart HA
- enter config/api token in configuration.yaml
- restart again.
It should work now
tellblom
(Tellblom)
4
Thanks, that seems to have solved the problem (and a lot of time
