Hey, so after having issues setting up hacs, I finally have it working. As expected it broke some custom cards I already I had. However, what I did not expect was it not actually creating the custom card types. So when I install the new add on, all the files seem to be created and I add the lines to the resources section of my raw config, but I keep getting the custom element does not exist error. Specifically I cant get the animated weather card to work. Alternatively if I could fix my old dark sky animated card that would also be great. Any advice that puts me in the right direction would be amazing. Thanks in advance!
you need to show us what your resources section of your lovelace config looks like.
Also Have you restarted HA after installing the cards via HACS?
Thanks, I actually uninstalled all of the addons and removed them from the raw config and did it over again and that worked.
