Have HAOS installed and starting up in a VMWare Workstation VM using the prebuilt vmdk downloaded from homeassistant.io. It sees network, I can browse to http://homeassistant:8123 but once it gets to a certain point in the “Preparing Home Assistant” process, it will just loop through the following continuously. Not sure if Github is having an issue, or maybe the path HA wants is obsolete or something. Only item I found searching for the error was to make sure my network allows NTP, and I can access ntp.org with NetTime so I believe it does. Anyone know what my issue is?
2024-12-26 15:46:41.601 ERROR (MainThread) [supervisor.docker.interface] Can’t install ghcr.io/home-assistant/qemux86-64-homeassistant:2024.12.5: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.12.5&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error (“Head “https://ghcr.io/v2/home-assistant/qemux86-64-homeassistant/manifests/2024.12.5”: Get “https://ghcr.io/token?scope=repository%3Ahome-assistant%2Fqemux86-64-homeassistant%3Apull&service=ghcr.io”: context deadline exceeded”)
2024-12-26 15:46:41.602 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
2024-12-26 15:47:11.605 INFO (MainThread) [supervisor.docker.interface] Updating image Package qemux86-64-homeassistant · GitHub to Package qemux86-64-homeassistant · GitHub
2024-12-26 15:47:11.605 INFO (MainThread) [supervisor.docker.interface] Downloading docker image Package qemux86-64-homeassistant · GitHub with tag 2024.12.5.
