I have bought a Raspberry Pi 3 B+ and installed Hassbian on it.
I can succesfully connect it through SSH when it’s connected either through an ethernet cable or through wifi. However, how much I try, I cannot get the frontend working.
Go to your home assistant configuration directory (the default path is /home/homeassistant/.homeassistant/) and open the home-assistant.log file to see if it shows any errors.
I have the same problem. I can connect to my pi (hassbian) through putty, but can not go the front page of HASS. Any one have any suggestion?
home-assistant@homeassistant: active
