I’m trying to use a 4GB USB stick to setup my new Yellow PoE (Rev 1.3) with a CM4 Lite (CM4004000
) and a 500GB NVMe (SNV2S
). Yellow LED just gets to the 1Hz flashing and never goes solid.
Plugging in via USB-C UART, I can get in via the serial terminal and log in as root
I have an IP. curl
and wget
don’t have DNS resolution. nslookup
works as expected. I can ping
the internet:
# ifconfig
end0 Link encap:Ethernet HWaddr D8:3A:DD:BC:C0:46
inet addr:10.255.0.9 Bcast:10.255.3.255 Mask:255.255.252.0
inet6 addr: fe80::da3a:ddff:febc:c046/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:3623 errors:0 dropped:476 overruns:0 frame:0
TX packets:108 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:455015 (444.3 KiB) TX bytes:9751 (9.5 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:64 errors:0 dropped:0 overruns:0 frame:0
TX packets:64 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:5056 (4.9 KiB) TX bytes:5056 (4.9 KiB)
# ping google.com
ping: bad address 'google.com'
# ping 1.1.1.1
PING 1.1.1.1 (1.1.1.1): 56 data bytes
64 bytes from 1.1.1.1: seq=0 ttl=53 time=10.020 ms
64 bytes from 1.1.1.1: seq=1 ttl=53 time=10.306 ms
--- 1.1.1.1 ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 10.020/10.163/10.306 ms
# wget http://version.home-assistant.io/stable.json
wget: bad address 'version.home-assistant.io'
# curl https://version.home-assistant.io/stable.json
curl: (6) Could not resolve host: version.home-assistant.io
# nslookup version.home-assistant.io
Server: 10.255.0.1
Address: 10.255.0.1:53
Non-authoritative answer:
Address: 104.26.4.238
Address: 104.26.5.238
Address: 172.67.68.90
Address: 2606:4700:20::681a:5ee
Address: 2606:4700:20::ac43:445a
Address: 2606:4700:20::681a:4ee
# date
Tue Dec 20 18:38:47 UTC 2022
I’ve also tried the other manual methods to install. It seems the rpiboot
method doesn’t work with the CM4 Lite - every time I try, the rpiboot
completes successfully but it doesn’t show up in the Raspberry Pi Imager.
I did notice that the date was very wrong. Maybe the RTC battery died? (Edit: the battery tests fine) Don’t see how this could prevent DNS from working - but maybe it would? Or the installer has some other DNS method and it’s https that’s failing? Seems like it should handle this discrepancy…
Not sure how to proceed here. Would love any thoughts.
