Installing ESPhome on GEEKMAGIC Smart Weather Clock (smalltv/pro)
Try turning the backlight on :slight_smile:
I’ve got a the Nixie clock version of this that appear to be a esp8266 , with you pin number I’ve got the screen and backlight working, with the adafruit gfx library and the adafruit st7789 library. This board also appears to have some leds I don’t know if they are addressable or RGB, no one would have any ideas? Ideas on the pins?
Great work so far I got the screen working pretty quick
A point to the device please.
Don’t know if anyone is interested, but turned out to be addressable led on pin 12 , trying to work out the touch sensor now
Hi!, could you upload the whole config, i’m trying to make it work using some code just read from this post but no luck the screen is on but nothing in it and i can ping it but no able to view logs from ESPhome, i have the one with the esp8266
esphome:
  platform: ESP8266
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: "REDACTED"
ota:
wifi:
  ssid: !secret wifi_ssid
  fast_connect: True
  manual_ip:
    static_ip: 192.168.x.xxx
    gateway: 192.168.xx.xx
    subnet: 255.255.255.0
captive_portal:
time:
  - platform: homeassistant
font:
  - file: 'fonts/OpenSans-Regular.ttf'
color:
    - id: color_green
      red: 0%
      green: 100%
      blue: 0%
  # Uptime sensor
  - platform: uptime
  # WiFi Signal sensor
  - platform: wifi_signal
    name: "WiFi Signalstärke"
    update_interval: 60s
spi:
  clk_pin: GPIO14
  mosi_pin: GPIO13
  interface: hardware
output:
  - platform: esp8266_pwm
    pin: GPIO05
    frequency: 20 Hz
light:
  - platform: monochromatic
    output: pwm_output
display:
  - platform: st7789v
    model: "Custom"
    spi_id: spihwd
    height: 240
    width: 240
    offset_height: 0
    offset_width: 0
    dc_pin: GPIO02
    reset_pin: GPIO04
    #backlight_pin: GPIO25
    eightbitcolor: True
    #update_interval: never
    update_interval: 5s
    spi_mode: mode3
    lambda: |-
      it.printf(0, 0, id(font1), id(color_green),"Test1");
      it.printf(1, 1, id(font1), id(color_green),"Test2");
      it.printf(10, 10, id(font1), id(color_green),"Test3");
      it.printf(100, 100, id(font1), id(color_green),"Test4");
Mine is the esp32 so I’m probably no good to you.
Hi @laurentdb did you get this working? if it so, could you please share your config file :slight_smile:
Also I changed my yaml and seen to have bricked the darn thing.
Good news… My Display just arrived and I was disappointed to see that it was ESP8266…
But after little poking around, I got the screen working… didn’t do full test! but this is my config
esphome:
  friendly_name: Mini Display TV - Yellow
esp8266:
  board: esp01_1m
external_components:
  - source:
      type: git
      url: https://github.com/rletendu/esphome.git
      ref: st7789_nobuffer_202312
    # refresh: 0s
    components: [st7789v]
# Enable logging
logger:
api:
  encryption:
    key: "xxx"
ota:
  password: "xxx"
wifi:
  ssid: xxx
  password: xx
  ap:
    ssid: "Mini-Display-Tv--Yellow"
    password: "xxxxxxx"
# captive_portal:
spi:
  clk_pin: GPIO14
  mosi_pin: GPIO13
  interface: hardware
# status_led:
#   pin: GPIO2
output:
    pin: GPIO05
    frequency: 20 Hz
light:
    output: pwm_output
font:
  # gfonts://family[@weight]
  - file: "gfonts://Roboto"
color:
  - id: color_green
    red: 0%
    green: 100%
    blue: 0%
display:
  - platform: st7789v
    model: "Custom"
    spi_id: spihwd
    height: 240
    width: 240
    offset_height: 0
    offset_width: 0
    # dc_pin: GPIO02
    # reset_pin: GPIO04
    dc_pin: GPIO00
    reset_pin: GPIO02
    eightbitcolor: True
    update_interval: 5s
    spi_mode: mode3
    lambda: |-
      auto red = Color(255, 0, 0);
      auto green = Color(0, 255, 0);
      auto blue = Color(0, 0, 255);
      auto white = Color(255, 255, 255);
      it.rectangle(20, 50, 30, 30, white);
      it.rectangle(25, 55, 30, 30, red);
      it.rectangle(30, 60, 30, 30, green);
      it.rectangle(35, 65, 30, 30, blue);
Hope this helps others :wink:
Only different is the DC & RESET pins
dc_pin: GPIO00
reset_pin: GPIO02
it is really slow to render… simple text is taking 0.33 s to render. A Full screen image is taking 2-3seconds to render!
not sure how to improve this…
I’m 99% confident that this product is based on this project GitHub - ClimbSnail/HoloCubic_AIO: HoloCubic超多功能AIO固件 基于esp32-arduino的天气时钟、相册、视频播放、桌面投屏、web服务、bilibili粉丝等
Hope that will make anything simpler.
Does anyone have a dump of the “ultra” model, I can’t seem to get the old image flashed from the github, just black screens on the screen itself.
Nevermind!
Update: I have never used esphome so I realize this makes me look like a PSYCHO
Is there a way to restore the original firmware after uploading esphome?
I’m also looking for dump (original FW) of PRO and ULTRA version.
But no luck so far …:sob:
I have uploaded the partition table and a dump of all but the spiffs partitions here: Unbricking · Issue #10 · GeekMagicClock/smalltv-pro · GitHub
Which device is recommended, Pro or Ultra?
What is this ultra? The first post refers to the smalltv and the smalltv pro. Where did the ultra come into it, and can you point to an example for sale?
They have some on this page as well as some of the standard ones, a couple of others have mentioned them in this thread.
I use the octopus Agile energy tariff, and I see these as great devices to put in rooms to say when energy is cheapest.
https://www.aliexpress.com/item/1005004679769445.html
