Installing ESPHome on Sonoff Bridge R2
Hey All…I’m new to ESPHome, and I’m struggling with my first programming task. I’m trying to get my Sonoff Bridge R2 set up with ESPHome, in order to control my awning via 433MHz. I have Home Assistant & ESPHome running in Docker on a ‘server’. S
I’ve had a couple of interations of my rf-bridge-1.yaml config file, but here’s the latest:
esphome:
  friendly_name: rf-bridge-1
esp8266:
  board: esp01_1m
# Enable logging
logger:
  baud_rate: 0
# Enable Home Assistant API
api:
  encryption:
    key: !secret esphome_api_key
ota:
- platform: esphome
  password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Rf-Bridge Fallback Hotspot"
    password: !secret rf_bridge_fallback_hotspot
I’m programming using my Macbook Air. I have a FT232 USB UART Board (Type C) module connected to my Sonoff Briidge R2 via the following pinout:
UART VCCIO (set to 3.3v) → RF Bridge 3V3
UART GND → RF Bridge GND
UART RX → RF Bridge TX
UART TX → RF Bridge RX
I’ve tried using ESPFlasher, but lately I’ve been using ESPHome installer via Home Assistant. Here’s my latest process:
After validating my config, I run ‘install’ and choose ‘Plug Into this computer’. I then download the BIN file and click ‘Open ESPHome Web’. I then click Connect, and while holding the power button on the RFBridge and connect the UART to my laptop. From there I’ve tried both the ‘Prepare for first use’ and ‘Install’ (providing the bin file) options, both to no avail.
Any insights?
I used this guide to flash mine: https://www.irrgang.dev/how-to-flash-the-sonoff-rf-bridger2-with-esphome/
Thanks @desean - I referenced the same guide when I first started, but was still having issue. I just can’t see what I was doing wrong.
Looking at your YAML above, it doesn’t seem like you have followed the guide though, as it looks incomplete.
Here is my full YAML, which you might want to compare.
#Sonoff RF BridgeR2 https://www.irrgang.dev/how-to-flash-the-sonoff-rf-bridger2-with-esphome/
substitutions:
  friendly_name: Sonoff RF Bridge
esphome:
  friendly_name: ${friendly_name}
  comment: Sonoff RF BridgeR2 with ESPHome
esp8266:
  board: esp01_1m
# Enable logging
logger:
  baud_rate: 0
api:
  encryption:
    key: !secret sonoff_rf_bridge_encryption_key
  services:
    - service: send_rf_code
      variables:
        sync: int
        low: int
        high: int
        code: int
      then:
        - rf_bridge.send_code:
            sync: !lambda 'return sync;'
            low: !lambda 'return low;'
            high: !lambda 'return high;'
            code: !lambda 'return code;'
    - service: learn
      then:
        - rf_bridge.learn
rf_bridge:
  on_code_received:
    then:
      - homeassistant.event:
          event: esphome.rf_code_received
            sync: !lambda 'return format_hex(data.sync);'
            low: !lambda 'return format_hex(data.low);'
            high: !lambda 'return format_hex(data.high);'
            code: !lambda 'return format_hex(data.code);'
ota:
  - platform: esphome
    password: !secret sonoff_rf_bridge_ota_pwd
wifi:
  ap:
    ssid: "${friendly_name} ESP"
    password: !secret sonoff_rf_bridge_ap_pwd
button:
  # Restart the ESP
  - platform: restart
uart:
  tx_pin: 1
  rx_pin: 3
  baud_rate: 19200
captive_portal:
# Sensors for ESP version and WIFI information
text_sensor:
  # ESPHome version
  - platform: version
    hide_timestamp: true
  # IP address and connected SSID
  - platform: wifi_info
    ip_address:
      icon: mdi:wifi
    ssid:
      icon: mdi:wifi-strength-2
  # WiFi signal
  - platform: wifi_signal
    update_interval: 120s
  - platform: uptime
binary_sensor:
  - platform: status
light:
  - platform: status_led
    pin: GPIO13
