Package sudo is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available form another source
tonight I’m going to re-install Debian 9 using the network install instead of USB install.
What method did you guys that use Debian use to install HA?
When you have it running, run sudoers (can’t remember if you need to download it) and add your username to the sudoers then it won’t ask for your password every time you enter a command…
You’ll need to google sudoers for the exact command switches.
David - I think you mean ‘visudo’? That’s the command that lets you edit the /etc/sudoers file. You can edit it directly, but visudo is a bit more secure - checks permissions etc after your edit.
@ramdisk - I imagine you must have something confused in your /etc/apt/sources.list file or in one of the files within /etc/apt/sources.list.d/ - I install Debian on some machine or VM every couple of weeks, using a variety of methods, and I can’t recall ever failing to install sudo :-). But you may find a clean install to be the easiest if you haven’t done much work on it so far.
I installed from USB using i386 Debian image…not sure what you mean “i386 Debian” may be my issue. I’m a newbie to all this Linux stuff…spent 7hrs reading about how to install HASSIO on Linux, loading re-loading Debian with no password for root, trying to install docker and all I have is unable to locate packages and errors. Maybe I just missed something but it sure is frustrating not sure where to turn any help be appreciated
OMG I just got docker installed in ubuntu server 18.04.
I know this is going to sound stupid but under ubuntu I had to get to root to install docker, yes I tried under Debian as root.
Did not know that Docker needs 64bit version, thanks
Ah, yes, you do need a 64-bit Linux for this. (An ‘amd64’ rather than ‘i386’ architecture.)
These days it’s almost impossible to find an i386 version of Ubuntu Server, but Debian (my preference) still supports both so it’s an easier mistake to make!
