Installing HA OS 12.2 in a virtualized KVM (virtual manager) using rasperry PI 5 and Rasperry pi OS not working
I´m trying to get the best of both worlds using my new Rapi5 for HA and also other usages.
Using Rapi5 just for HA would be and overkill and besides that I use RemotePC to acess my Pi remotely, as It´s under a network that does not accept incoming calls and RemotePC solves this for me. RemotePC has a version for Rasperry PI OS but not for HA.
Under HA installation instructions I see it should be supported because there is a linux installation section that describes the configuration in order to use virtual Manager to run HA OS under it.
I´ve followed the steps but it seems I cannot get a non secure boot firmware from the current version of virtual manager installed so I´d like to know how to boot HA OS using secure boot or, if not possible, how to disable secure boot in a Rapi5 in order to thet HA OS running. I´ve tried different linux machines configuration in virtualmanager, such as generic linux 2022/2020, gentoo linux, and even Ubuntu 16, but all this machine configurations come with secure boot enabled…
Any ideas?
Maybe you can take some tips from
I haven’t read through HA install tips, but I noticed that in recent setups with QEMU/libvirtd/KVM, the firmware in the VM defaults to secure boot. So you need to go into UEFI firmware settings and disable secure boot. This is Debian 12, I assume you run RPiOS64 Bookworm on your Pi5, so that is same version.
Just to confirm, are you talking about step 6 which says:
“Under customization select Overview > Firmware > UEFI x86_64: …. Make sure to select a non-secureboot version of OVMF (does not contain the word secure, secboot, etc.), e.g., /usr/share/edk2/ovmf/OVMF_CODE.fd.”
Exactly, the problem is that this step 6 is directed towards Generic Linux for Intel and the Rapi5 OS as it´s arm64 based has different naming conventions. For instance, instead of OVMF prefix the firmware prefix starts wi AAVMF… I cannot find a AAVMF file that would support a non-secureboot version…
The problema is that besides having the OS version difference the processor architecture is different as well. I´ve just realised that the image provided in the HA site (https://github.com/home-assistant/operating-system/releases/download/12.2/haos_ova-12.2.qcow2.xz) is probably a Intel 86_x64 image so it should not run in a arch64 arquitecture (Rapi5 arm processor).
Probably I was able to overcome the secure boot because the initial message “security violation” disappeared when I used a old machine type in virt-manager and changed the security boot parameter and disabled it, but I thought it didn´t work.
Probably it worked and now my problema is to get or make a qcow2 image based on arm64… Anyone knows how to solve this issue?
Looking at HA´s rasperry pi instalattion instructions it does not talk about using a hypervisor like virt-manager and the image is built in rasperry pi image builder…
Yes, you need https://github.com/home-assistant/operating-system/releases/download/12.2/haos_generic-aarch64-12.2.qcow2.xz for a Pi 5
For ARM, things might not be correct. I remember on RPiOS Bullseye, those UEFI firmware files simply weren’t installed automatically, they might even be missing from the Debian repo. I used also Opensuse Tumbleweed at that time, there everything was there in the correct way. I actually copied the AAVMF files from Tumbleweed to RPiOS in order to get VMs running. Now in Bookworm, files should be there, but it might be that you need to extra install some Debian package for it, I don’t remember anymore.
EDIT:
Now is see they are in Debian package: qemu-efi-aarch64
# dpkg -L  qemu-efi-aarch64
/usr
/usr/share
/usr/share/AAVMF
/usr/share/AAVMF/AAVMF_CODE.fd
/usr/share/AAVMF/AAVMF_VARS.fd
/usr/share/AAVMF/AAVMF_VARS.ms.fd
/usr/share/AAVMF/AAVMF_VARS.snakeoil.fd
/usr/share/doc
/usr/share/doc/qemu-efi-aarch64
/usr/share/doc/qemu-efi-aarch64/README.Debian
/usr/share/doc/qemu-efi-aarch64/changelog.Debian.gz
/usr/share/doc/qemu-efi-aarch64/copyright
/usr/share/qemu
/usr/share/qemu/firmware
/usr/share/qemu/firmware/40-edk2-aarch64-secure-enrolled.json
/usr/share/qemu/firmware/50-edk2-aarch64-secure.json
/usr/share/qemu/firmware/60-edk2-aarch64.json
/usr/share/qemu-efi-aarch64
/usr/share/qemu-efi-aarch64/PkKek-1-snakeoil.key
/usr/share/qemu-efi-aarch64/PkKek-1-snakeoil.pem
/usr/share/qemu-efi-aarch64/QEMU_EFI.fd
/usr/share/AAVMF/AAVMF_CODE.ms.fd
/usr/share/AAVMF/AAVMF_CODE.snakeoil.fd
This is part of the VM XML file I run HA in:
  <os firmware="efi">
    <type arch="aarch64" machine="virt-7.2">hvm</type>
    <firmware>
      <feature enabled="no" name="enrolled-keys"/>
      <feature enabled="no" name="secure-boot"/>
    </firmware>
    <nvram>/var/lib/libvirt/qemu/nvram/harmos_VARS.fd</nvram>
Yes, the solution was very simple but I had to look lots of different threads so I´m summarizing here a step by step procedure in order to get a Rasperry PI5 (bookworm 64 bit OS) running HA OS 12.2 inside a virtual manager KVM
1o) install virtual manager:
sudo apt install virt-manager
2o) Download HA OS for arm64bit arquitecture:
This is the link for the 12.2 version, but you can browse github for the version you want:
NOTE: This is the trick, it is not mentioned in the HA linux installation page. There, implicitily, it assumes that you´re running an intel/amd (x86_64) arquitecture so the qcow2 files provided are for intel not arm arquitecture and the configuration of virtual manager refers just to x86 and x86_64 platforms. It took me 2 days to figure out that.
In othe words DON´T USE the image provided in the HA Linux installation page for Rasperry PI installations, use the link above.
3o) launch virtual machine manager (GUI) and create a machine
Basically select the import disk image option and use all the default options(virt type KVM, architecture aarch64, machine type virt)
Click forward and select the aarch64-12.2.qcow2 that you´ve previously decompressed in a suitable path
selecting generic linux 2022 as the operating system you are installing.
Select the Bridge for networking (beyond the scope of this post, but HA will boot even without networking configured which can show you´ve sucessfully installed in the VM)
You me let the default UEFI firmware but there is a trick. The first time you run the virtual machine it´s not going to boot. It´s going to show “security violation”. This is due the secure boot being enabled and HA does not support that. The workaround is very easy. Just press enter, this will take you to the Firmware setup (When I was young it was called BIOS setup kkkkkk).
There you go to device manager and disable secure boot and restart.
The magic will happen!!, HA OS will boot and after a while the root login will appear. This workaround has to be done just once, the VM persist the new firmware setup. There is an option which is look for a already non-secure boot UEFI firmware for aarch64. It would take me time for that and the workaround takes 30 seconds and done.
That´s it, you got HA installed. It took me some hours to figure out how to setup a bridge and get it used by HA network but I think this is beyond the scope of this post, there are a lot of posts and youtube videos regarding bridges and Debian
:pray:
Thanks! Amazing U make it working, i planning to the SAME on Rpi 5 running Rpi OS on 256GB SD card then HAOS on external SSD via USB, but later on internal nvme SSD!
I don’t need USB Zigbee stick or USB Sensors but for example have camera/microphone or touch screen connect to Rpi 5 would be
accessible for HAOS running in KVM
This was very helpful, though I am getting nowhere with a bridge or default QEMU network.
When using Docker, all is fine (can connect from my local network and devices are found). When using KVM/QEMU/libvirt I can connect from the Pi5 or from the local network with port forwarding, but no new devices are found. Seems weird as Docker can clearly set up the network but QEMU seems to block something. Playing with iptables has got me nowhere. Help!
I followed these steps and I was able to install on a Pi4B.
However, the restoration of my configuration backup for the HA Supervised I was running previously failed because there was insufficient storage in the VM. I used the haos_generic-aarch64-12.2.qcow2.xz.
Is there an image somewhere with predefined larger storages, like 32GB?
The haos_generic-aarch64-12.2.qcow2.xz.comes with a 32Gb disk
You may need to research this a bit, but a few years ago, all I did basically was shutdown the VM, use the command qemu-img resize YOUR_IMAGE.qcow2 +16G (or however many gigs you want to add) and then restart the VM. The physical image on the host didn’t automatically increase in size, but the HAOS automatically increased its /dev/sd8 partition and as the used portion of sd8 increased, so did the physical image.
That doesn’t look right, or I am missing something.
PS: I am new to this .qcow thing.
I have installed using that image and this is what I see:
Welcome to Home Assistant
homeassistant login: root
Warning: your password will expire in 0 days.
Welcome to Home Assistant OS.
Use `ha` to access the Home Assistant CLI.
# lsblk
NAME   MAJ:MIN RM  SIZE RO TYPE MOUNTPOINTS
zram0  253:0    0    0B  0 disk
zram1  253:1    0   32M  0 disk
zram2  253:2    0   16M  0 disk /tmp
vda    254:0    0    6G  0 disk
|-vda1 254:1    0   32M  0 part /mnt/boot
|-vda2 254:2    0   24M  0 part
|-vda3 254:3    0  256M  0 part /
|-vda4 254:4    0   24M  0 part
|-vda5 254:5    0  256M  0 part
|-vda6 254:6    0    8M  0 part
|-vda7 254:7    0   96M  0 part /var/lib/systemd
|                               /var/lib/bluetooth
|                               /var/lib/NetworkManager
|                               /etc/systemd/timesyncd.conf
|                               /etc/hosts
|                               /etc/hostname
|                               /etc/NetworkManager/system-connections
|                               /root/.ssh
|                               /root/.docker
|                               /etc/udev/rules.d
|                               /etc/modules-load.d
|                               /etc/modprobe.d
|                               /etc/dropbear
|                               /mnt/overlay
`-vda8 254:8    0  5.3G  0 part /var/log/journal
                                /var/lib/docker
                                /mnt/data
# df -h
Filesystem                Size      Used Available Use% Mounted on
/dev/root               200.9M    200.9M         0 100% /
devtmpfs                  1.9G         0      1.9G   0% /dev
tmpfs                     1.9G         0      1.9G   0% /dev/shm
tmpfs                   781.8M      1.1M    780.8M   0% /run
tmpfs                   781.8M      1.1M    780.8M   0% /etc/machine-id
/dev/vda1                31.9M    792.0K     31.1M   2% /mnt/boot
/dev/vda7                84.5M     78.0K     77.7M   0% /mnt/overlay
/dev/vda7                84.5M     78.0K     77.7M   0% /etc/dropbear
/dev/vda7                84.5M     78.0K     77.7M   0% /etc/modprobe.d
/dev/vda7                84.5M     78.0K     77.7M   0% /etc/modules-load.d
/dev/vda7                84.5M     78.0K     77.7M   0% /etc/udev/rules.d
/dev/vda7                84.5M     78.0K     77.7M   0% /root/.docker
/dev/vda7                84.5M     78.0K     77.7M   0% /root/.ssh
/dev/vda7                84.5M     78.0K     77.7M   0% /etc/NetworkManager/system-connections
/dev/vda7                84.5M     78.0K     77.7M   0% /etc/hostname
/dev/vda7                84.5M     78.0K     77.7M   0% /etc/hosts
/dev/vda7                84.5M     78.0K     77.7M   0% /etc/systemd/timesyncd.conf
/dev/vda8                 5.2G      1.9G      3.0G  39% /mnt/data
/dev/zram2               15.0M     80.0K     13.8M   1% /tmp
tmpfs                     1.9G         0      1.9G   0% /var
/dev/vda7                84.5M     78.0K     77.7M   0% /var/lib/NetworkManager
/dev/vda7                84.5M     78.0K     77.7M   0% /var/lib/bluetooth
/dev/vda8                 5.2G      1.9G      3.0G  39% /var/lib/docker
/dev/vda7                84.5M     78.0K     77.7M   0% /var/lib/systemd
/dev/vda8                 5.2G      1.9G      3.0G  39% /var/log/journal
overlay                   5.2G      1.9G      3.0G  39% /mnt/data/docker/overlay2/b1fc11b1ad652ac624109afec04f72e0f4366cd02b99fb6b53363356f442c291/merged
overlay                   5.2G      1.9G      3.0G  39% /var/lib/docker/overlay2/b1fc11b1ad652ac624109afec04f72e0f4366cd02b99fb6b53363356f442c291/merged
overlay                   5.2G      1.9G      3.0G  39% /mnt/data/docker/overlay2/98ce734aef2d2e0c8421529187f1bfd4f58e3da530dbf9fc14d4dbbab86edf6a/merged
overlay                   5.2G      1.9G      3.0G  39% /var/lib/docker/overlay2/98ce734aef2d2e0c8421529187f1bfd4f58e3da530dbf9fc14d4dbbab86edf6a/merged
overlay                   5.2G      1.9G      3.0G  39% /mnt/data/docker/overlay2/7c0d4b7420768d5a520dede00276bde52a025d040598b7bd615f6abcbb5254fe/merged
overlay                   5.2G      1.9G      3.0G  39% /var/lib/docker/overlay2/7c0d4b7420768d5a520dede00276bde52a025d040598b7bd615f6abcbb5254fe/merged
overlay                   5.2G      1.9G      3.0G  39% /mnt/data/docker/overlay2/eb736eee3180415786ea43c6b2e7428df9919f977b3fb1d87688acb0eff77113/merged
overlay                   5.2G      1.9G      3.0G  39% /var/lib/docker/overlay2/eb736eee3180415786ea43c6b2e7428df9919f977b3fb1d87688acb0eff77113/merged
overlay                   5.2G      1.9G      3.0G  39% /mnt/data/docker/overlay2/77b44f946430ef9c2314741a5135067fba8efa2bb59d494fcad44e78b4877271/merged
overlay                   5.2G      1.9G      3.0G  39% /var/lib/docker/overlay2/77b44f946430ef9c2314741a5135067fba8efa2bb59d494fcad44e78b4877271/merged
overlay                   5.2G      1.9G      3.0G  39% /mnt/data/docker/overlay2/da988b1f96041c0c4ad50ce5e2524e3530a4a229e3657bd272a7bb1b93bdd4c1/merged
overlay                   5.2G      1.9G      3.0G  39% /var/lib/docker/overlay2/da988b1f96041c0c4ad50ce5e2524e3530a4a229e3657bd272a7bb1b93bdd4c1/merged
overlay                   5.2G      1.9G      3.0G  39% /mnt/data/docker/overlay2/5e71a436f4d8798f8f41e4d87993e80c1f02b2b6da763ee084bd1782d3bf37a0/merged
overlay                   5.2G      1.9G      3.0G  39% /var/lib/docker/overlay2/5e71a436f4d8798f8f41e4d87993e80c1f02b2b6da763ee084bd1782d3bf37a0/merged
That resolved the issue. I was able to go through the restoration of my backup config.
Thank you.
I managed to do it in one command including network direct to eth0 and security off:
sudo virt-install --name haos --description "Home Assistant OS" --os-variant=generic --ram=6144 --vcpus=2 --disk haos_generic-aarch64-16.2.qcow2,bus=scsi --controller type=scsi,model=virtio-scsi --import --graphics none --boot uefi \
             --noautoconsole \
             --network network=default,model=virtio,mac=52:54:00:fa:72:01  \
             --network direct,source=eth0,source_mode=bridge,model=virtio,mac=52:54:00:4a:19:02  \
			 --boot uefi,firmware.feature0.name=enrolled-keys,firmware.feature0.enabled=no,firmware.feature1.name=secure-boot,firmware.feature1.enabled=no
16.2 version: https://github.com/home-assistant/operating-system/releases/download/16.2/haos_generic-aarch64-16.2.qcow2.xz
All together this will do it all (tested on Pi5):
sudo virsh net-start default
sudo virsh net-autostart default
wget https://github.com/home-assistant/operating-system/releases/download/16.2/haos_generic-aarch64-16.2.qcow2.xz
unxz haos_generic-aarch64-16.2.qcow2.xz
sudo qemu-img resize haos_generic-aarch64-16.2.qcow2 +32G
             --noautoconsole \
sudo virsh autostart haos
I wrote a guide on GitHub how to do it on a Raspberry Pi 5.
It also has a script which does everything automatically.
I hope this helps.
