Installing HACS on Qnap Homeassistant
Hi, I am still very new to homeassistant. I have recently installed HA on my qnap and got it up and running however I am running into two problems at the moment.
Firstly I cant seem to get HACS to install. I go into Container Station and I can see that I have a docker version of HA running. I click on the terminal button and enter
wget -O - https://get.hacs.xyz | bash -
This returns the following message
    if [ "${currentMonth}" -lt "${targetMonth}" ]; then
    rm -R "$haPath/custom_components/hacs"
        error "Version ${currentVersion} is not new enough, needs at least ${targetVersion}"
    fi
    if [ "${currentMonth}" == "${targetMonth}" ]; then
        targetPatch=$(echo "${targetVersion}" | cut -d "." -f 3)
        currentPatch=$(echo "${currentVersion}" | cut -d "." -f 3)
        if [ "${currentPatch}" -lt "${targetPatch}" ]; then
        fi
    fi
fi
echo
info "Removing HACS zip file..."
rm "$haPath/custom_components/hacs.zip"
info "Installation complete."
echo
info "Remember to restart Home Assistant before you configure it"
else
echo
error “Could not find the directory for Home Assistant” false
echo “Manually change the directory to the root of your Home Assistant configuration”
echo “With the user that is running Home Assistant”
echo “and run the script again”
exit 1
fi
  •                100% |********************************|  3988  0:00:00 ETA
written to stdout
wget: bad address ‘|’
Its a bit beyond me what is going wrong during the install of this.
When installing HA I made sure that I was using the latest stable release (2023.9.3)
My second issue is that I have plugged a skyconnect with the extension cable into a usb port in the Qnap. There does seem to be additional steps I need to do to get this to work but I am struggling here.
Any help for either issue would be much appreicated, thank you.
Hi, I have the same problem. Did you find a solution?
Hey, did you find a solution? I have the same problem just now…
Hi guys,
I have the same issue in Qnap Docker Container “Home Assistant”.
I have the solution!!
The command is correct but you make this command in \config.
You make:
-Open Container Station Qnap;
-Click Container Home-Assistant;
-Click Execute
-Click the square whit arrow whit command /bin/sh (this open an a web page with SSH command)
-Now you past the command " wget -O - https://get.hacs.xyz | bash -"
-Restart Container and search HACS in your integration
Bye Bye Guys
