Try adding sudo
to the beginning of the last command like below
sudo qemu-img convert -O raw haos_ova-10.2.qcow2 /dev/zvol/Backup/apps/haos
Try adding sudo
Hi, i have the same problem with trying to get the coral usb to passthrough. The problem is i cant see it in truenas scale so i cant choose it to passthrough. Is there something i need to do first like install drivers or something?
Iām not sure about the Coral devices. You might have better luck asking in the TrueNAS forums how to get the USB Coral working SCALE VMs. I donāt mean to send you away, but I can only help with things I have experience with. I think youāll get more eyes in your own thread and more experienced TrueNAS users on their forum.
TrueNAS Scale, though built from Debian, is intended to be an appliance. There is no support for modifying the underlying OS to install drivers
Will do, thanks!
I went down this rabbit hole this week. I got it working for Frigate as an app but I assume you should be able to pass it to a VM as well.
PM me and Iāll send you what I did.
On my old nas I was able to access the config files via smb. Since this is a zvol, has anyone figured out a way to get access?
Iāve used either the SAMBA add-on or the SSH add-on for this.
The only way I know, without using an add-on, is to enable SSH to HAOS itself.
thanks for this, it installs and looks like its running but no usernames or passwords are being accepted
Done the same like in the guide. But nothing shows up. If i click monitor i just see some shell, thats all but no life signs from homeassistant
same problem here. Seems that the qemu command isnāt availble in truenas core 13ā¦ so weāre stucked indeed.
Hi folks,
Sorry, Iām away and unable to help with installation issues for some time.
That is correct ā This guide is for TrueNAS SCALE, which is the Linux-based version of TrueNAS.
TrueNAS CORE is based on FreeBSD and uses a different hypervisor which is why the qemu
command is unavailable. The good news is, that you can still install HAOS in a VM on TN CORE following this guide instead
@Elfir If you find a way of doing this Iād be interested to know what you did. Iām still looking and if I have any success Iāll let you know.
Hello everyone.
Iām instaling se haos on a VM as @troy 's instructions. It work smoothly until the onboarding screen.
I was able to create my account, but on the next screen, the country field is missing and I canāt move to the next stepā¦
I did the instalation twice and had the same resultā¦
Any sugestions?
can you manually edit these values and continue? skip?
@aelg305 I can edit all fields but the country. Whe I click next, it show an error message and I canāt go past this screen.
I donāt know if there any file I can manually edit to baypass this errorā¦
Iām still trying to figure out what is happeningā¦
I created a VM on a Windows computer (virtualbox) and tried several versions of HAOS (10.3 to 9.0) and everytime the result was the same: there is no country selector and I canāt go beyond this screenā¦
I donāt know if if something related to this, but Iām from Brazilā¦ Is there some issue relate to my ip address?
Hi Fabiano,
This sounds like it could be a bug within Home Assistant itself. Maybe consider filing a bug report.
Yes, I was thinking the sameā¦ Thanks for your reply.
hi,
Iām facing an issue when I try to add Skyconnect to my HA running on freeness.
I tried the guide but when I run the command
"freenas[]> system advanced update kernel_extra_options=āmodule_blacklist=cp210xā
I receive:
invalid arguments: kernel_extra_options
File "/usr/local/bin/cli", line 10, in <module>
sys.exit(main())
File "/usr/local/lib/python3.9/site-packages/midcli/__main__.py", line 109, in main
cli.run()
File "/usr/local/lib/python3.9/site-packages/midcli/__main__.py", line 95, in run
self.context.do_input(parsed)
File "/usr/local/lib/python3.9/site-packages/midcli/context.py", line 277, in do_input
namespace = self.current_namespace.do_input(text)
File "/usr/local/lib/python3.9/site-packages/midcli/context.py", line 61, in do_input
return i.do_input(parsed)
File "/usr/local/lib/python3.9/site-packages/midcli/context.py", line 64, in do_input
i.do_input(parsed)
File "/usr/local/lib/python3.9/site-packages/midcli/command.py", line 177, in do_input
for name, v in args.items():
AttributeError: 'NoneType' object has no attribute 'items'
freenas%
How I can solve? the device is not shown in the /dev/serial
thanks in advice
Hi dinoc93,
Other users have reported the sky connect should just work with USB pass through in your VM settings.
I donāt think you need to blacklist anything for the sky connect
