Hi all - first post! I just took delivery of a Raspberry Pi 5 with M.2 HAT+ and NVMe SSD, and before I’ve even started, I realised I can’t see an obvious way to set up HAOS on the SSD. Sure, I could use an SD card, but then how do I set up the SSD at that point.
Once I’m set up, I’ll be restoring the backup from my current Pi 3B running HAOS on an SD card. Can I even just move over the SD card to start with?
OK thanks, I’ll go that way if there are no other options. I think I’d rather put a build on the Pi if I can sort it from there. Let’s see if others have suggestions!
There may be other options, but for me it was very easy.
I uploaded HAOS to an SSD, put it in the Rpi5, and within a few minutes I had a working HA. Then I just used a backup from another HA and that was it.
Boot up on the MicroSD card, then install the OS on the NVME and set the device to boot from there if no MicroSDCard is present. Then turn the RPI off, take the card out, and reboot
Thanks all, in the end i worked out my issue was using an old usb sd card adaptor, the initial pios image had errors. Once i used a new one i realised how much faster the etcher was able to run, and create a reliable os to work with.
For anyone else looking for a solution you can do the following:
-Use the Raspberry Pi imager and install Raspberry Pi OS on a SD card.
-Boot the Pi from the SD card
-In Rasperry Pi OS, there is a version of the Pi imager in the Utilities.
-Use the Raspberry Pi imager to download HAOS and select the SSD as the destination.
It’s a waste of money (because other solutions offer more bang for the buck - ) but I went the route of this very fun what I call my “executive desk toy” -
I know this is old but want to confirm, do we need to change the boot order or config in the RPi 5’s eeprom if we want to use a M2 Hat for a nvme ssd? Or will it boot up just fine with the image on the SSD?
RPI will boot firstly form SD CARD,
when no SD card will boot from the rest of bootable devices in an order, probably nvme would be the last…
Nevertheless, to install Home Assistant OS on a raspberry pi5 which has an SSD over nvme
you need a min 16 gb sd card to use raspberry pi imager and create a sd card image with PI OS (desktop if you want it simple) (You can do this on windows os)
After image created, Plug the SD card, power on RPI, boot into PI OS, use PI Imager to create now an image of HA OS on the SSD which is installed in your RPI → you need to untick hide system devices when you need to select the drive, and select the SSD from top right corner of imager app
create this image
After image created, shutdown PI OS, remove SD card, and power ON RPI again → it will boot form your nvme SSD with HA OS
