I have a raspberry pi running docker and my homeassistant died.
What instructions let me install the hass.io on docker?
Tried some but did not et the “supervisor” menu and other.
please advise - really appreciated!
The names have changed there is no hassio. Check this post, pick the one you want, the name column contains links to the instructions:
Hello and thanks for the helpful link.
I wish I found it before…
It’s pretty easy to copy your config files between installation methods if you do want to change.
I would say that this is what I want
I have the Rasperry working again nos but I also have NUC since I feel the Rpi performance is too bad,
Can you advise how to move config?
Just copy everything in the config folder.
