I have the same hardware, but run it in docker under ubuntu. You should be able to just burn the hassos image onto the emmc using etcher. Just as you would with an sd card.
Yes I was thinking that. I’m using the official ODroid eMMC reader and the latest balenaEtcher but when I power on all I get it the solid blue light (no ‘heartbeat’), no output to screen and no IP.
Should I be placing the image into a specific folder on the eMMC or just letting it image the whole card.
I’m thinking that it’s something to do with the boot area for the eMMC??? Am I wiping that out when I write the Hass.io image?
Etcher takes the image and writes the unpacked filesystem onto the emmc. Everything you need to boot is on it. Just follow the instructions, especially the static IP setup section.
I can create Ubuntu, Ambrian etc images and boot, load and run so the board and memory is definitely OK
It seems that Hasss.io just won’t load from a eMMC? Unless there’s any other input I guess I’ll have to do as @nanobra1n has done and run thru Ubuntu and Docker
Yes … very straightforward. Make sure your have ‘reset’ the eMMC to the Android then push through with the Armbrian install, update with the addons included, then install Hass.io with the code line shown.
I’ve run it all a few times now and very happy with it all so far/ Hass.io run very fast and very reliable compared to SD
Looks like it’s time to revisit this topic due to latest blog post from Home Assistant.
I’ve found this issue on GitHub, but looks like it’s also abandoned.
Have anybody fixed this somehow?
I’ve also find this on github.
Have anybody succeeded with this recipe?
@m0thman Hi mate … I’m now running 3 systems with Ambrian Buster with the HA in Docker. So not using the XU4 image. I’m trying to read that post but my eyes are glazing over … are they saying that running HA in a Linux Docker wont work in the future?
I believe they are saying that Supervisor on Linux will be deprecated in future. So you’ll be able to run Home Assistant Core in docker in future, but with no supervisor.
If you’ve installed HA with armbian-config Softy tool, then you are running it with Supervisor.
