Hi!
If you’re installing directly on Python on the OSes mentioned in the topic (after manually installing
python3.12 from the OS repositories), you might have noticed a warning in your logs about versions of Sqlite before 3.40.1 being deprecated.
Worry not, you can actually download the RPMs for Fedora and install them. These three (in this order):
Note that higher versions will not work due to conflicts with core libs. But these work, fit the requirement, and will make the warning disappear.
You’re welcome.
