zeryc
(jd muller)
October 12, 2022, 6:26am
1
When installing Home Assistant on a raspberry pi 3b it does fine untill get get to downloading Docker and it hangs up for a while the it start sending out error’s here is one of them
22-10-12 01:39:45 ERROR (MainThread) [supervisor.store.git] Can’t clone GitHub - home-assistant/addons: Docker add-ons for Home Assistant repository: Cmd(‘git’) failed due to: exit code(128)
any help in this matter would be great
The install has worked fine for me on many occasions, including to a RPi3b (still in production use now) so there aren’t many parts to check.
If you use a tool like the Raspberry Pi Imager or Balena Etcher, it should also check the written file and by implication, the uSD card.
What is the size of the uSD card?
(has the filesystem run out of space?)
Is the uSD card already failing with a hardware issue?
(fake copies lie about the actual storage available)
Can you browse to GitHub from the same network?
