Now trying to do a fresh install of HA OS 5.10 (+snapshot) instead of upgrading from 5.3 via the GUI.
The very first thing that went wrong was that the Raspbee II serial address had flipped from “/dev/ttyAMA0” to “/dev/ttyS0” which borked Deconz installation. Luckily it started working after switching the address, although one of the Hue dimmers borked too and needed a battery reset.
I have the old HA OS 5.3 installation on a separate SSD now, so I can switch back to the 5.3 by simply switching the SSD when/if the 5.10 starts locking up again.
EDIT: Aaaand it locked up. At this point I’ll just give up and keep using the HA OS 5.3 until something actually breaks.
EDIT2: There is a chance that the problem is in the EEPROM, but I’m sick and tired of troubleshooting this mess so I’ll check it sometime later.
is there someone who found a workaround for the USB devices that doesn’t work until you unplug and replug them after a host reboot?
is there a solution to the problem?
Thanks for the great guide .
Running now for 2 weeks on the pi4 2gb with SSD. Only on usb 2.0 because the adapter won’t work on the usb 3.0. But i can deal with that.
Thanks! Took me a few tries because as it turns out the 32 bit version of the 5.10 core does not boot at all from SSD, only the 64 bit one does on my pi 4 2gb
Patriot Burst 240 gb
StarTech 3.1 adapter
Note: I find the 64 bit version less snappy. Even though I am now using a faster medium, some parts of HA like supervisor take significant longer to load, especially when accessed over https. Also the restore left me with a few failing integrations ( Toon and MariaDB for instance). Load averages have gone up considerably too which I find odd. Where I used to look at 0.0x load averages with the SD card/32bit bit version they are on my 64 bit/SSD version around 0.5x Not sure yet if I will continue to use this setup.
You need to stop the MariaDB prior to making the snapshot. If not it will be corrupted. If you use the google drive snapshot add on there is a setting to automatically stop it prior to making the snapshot.
I suggest that you completely exclude your history database from being snapshotted. No matter whether it is Maria or Sqlite. It considerably bloats the snapshots. And the history data is deleted after a short time anyway (default = 10 days).
I have the HA app installed on LineageOS 17 (Android 10) on a RPi 4 8G and it all works via a 4k TV, until the 15.6 inch FHD touch monitor arrives. Given the dramas associated with using an USB to SATA connection, has anyone given any thought to using a SATA HAT instead so it is a native SATA connection? For $40AUD, I think it might be worth a try.
Edit: I didn’t look closely enough. A SATA HAT is still based on an USB connector (USB3), bugger, since I was hoping to avoid USB altogether.
