Installing Home Assistant on CM3 and CM4 boards
Question: Is it possible to have the CM3+ and CM4 boards added to the Home Assistant Operating system image? The current one does not work because the boot configuration files are not genned in for the CM3 platform and even if I add them manually it doesn’t have the driver support for Ethernet or the storage controller.
Should be a simple addition. Currently I’m running the HAAS on standard Pi OS, but it would be nice to install the turnkey solution on my CM3/CM4’s in my Turing Pi.
Thanks!
@czunit Raspberry CM3+ · Issue #3298 · home-assistant/operating-system · GitHub
Thanks! Appreciate adding this!
