First of all thanks so much for this guide. Iβm not sure I should have tried it as I donβt have any Linux experience but Iβm always willing to give things to go! My aim is to have HA running as a VM in Proxmox. Iβve got as far as installing Proxmox on my Beelink PC (SE18 - i5, 8gb RAM, 256GB SSD) and am trying to install HA but get this error. Please can anyone help? TIA
@kanga_who, I suggest to remove the reference for a putty install. If SSH is needed, the user can add it after the Home Assistant OS VM creation.
Iβve never had the need to SSH into my Proxmox server
Do you honestly think that this would be anything other than what I say it is when I place it on our company blog?
Regardless, it is there for those that need, I know that a lot of our clients have found this usefulβ¦ but hey ho, each to their own, and I can understand why you wouldnβt want to use itβ¦
Regardless, if you are using proxmox, I would then do the same steps once you have installed HA. Take a backup of the VM and store it somewhere safe. Also then take your backups within Home Assistant. That way, if you ever need to (for examples decrease disk size), then this is easier as you have a vanilla install ready to go onto which you can upload your backupβ¦
hi there, I am running Home Assistant on a Raspberry Pi 4 with an SD Card in a docker container. If I create HA on Proxmox as per the guideline above, will I be able to do a full backup from the current set up to the new set up and have all the custom components and add-ons listed?
It installed no problems this time. Thanks for your quick help. Doing some testing moving from a TrueNAS Scale on bare medal to ProxMox running Scale and my VMβs that are finicky in Scale.
I recently bought a mini PC with a Celeron N5105, installed Proxmox 7 and created a new HA installation using the excellent script posted here. Then imported my config from my rPi, connected my ZWave and RFXTRX USB key⦠all working fine.
However every 2 to 12 hours the VM would either reboot or hang (NMI, kthread, β¦). Proxmox and other LXC containers keep running fine. Nothing usable in the journald log, it literally just reboots.
Tested a lot of things and eventually installed a second HA instance with no config and no USB passed trough⦠which shows the same behavior sadly. Memtest on the mini PC passed.
Left it running today without a network cable attached and any USB device attached and it is still running after 12 hoursβ¦
Anyone ever had anything similar occur? Maybe the DNS issue mentioned earlier in this thread?
Edit: few hours later both VM rebooted themselves again (at separate times). The reboot is inside the VM, not on proxmox side. So basically a fresh install of HA OS 8.2 with no config, no devices and no network connected is not working
Thanks! Trying that right nowβ¦ in the meantime I switched my βvanillaβ 8.2 install to 1 core and got my longest uptime so far.
Edit: 7.6 already died after a good hour, my VM with only one core still going 24+ hours. Anything related to proxmox / multiple cores I can check ? BIOS settings on the mini PC are the defaults.
Could also try running an older proxmox version or installing HA directly on the mini PC to observe the outcome, but the idea of buying this was to actually separate my AdGuard install from HA.
