This worked great! thanks
Apologies⦠I had gotten frustrated and restored a backup. I just went back to this and still get the same issues on a new try.
deb http://deb.debian.org/debian/ bookworm main non-free
deb-src http://deb.debian.org/debian/ bookworm main
deb http://security.debian.org/debian-security bookworm-security main non-free
deb-src http://security.debian.org/debian-security bookworm-security main
# bullseye-updates, to get updates before a point release is made;
# see https://www.debian.org/doc/manuals/debian-reference/ch02.en.html#_updates_ and_backports
deb http://deb.debian.org/debian/ bookworm-updates main non-free
deb-src http://deb.debian.org/debian/ bookworm-updates main
Python 3.11.2
apt.conf is not available.
Edit: The issue seems to stem specifically from py3clean:
Preparing to unpack .../python3-debian_0.1.49_all.deb ...
File "/usr/bin/py3clean", line 210, in <module>
main()
File "/usr/bin/py3clean", line 196, in main
pfiles = set(dpf.from_package(options.package))
File "/usr/share/python3/debpython/files.py", line 54, in from_package
stdout = str(stdout, 'utf-8')
UnicodeDecodeError: 'utf-8' codec can't decode byte 0x82 in position 6: invalid start byte
dpkg: warning: old python3-debian package pre-removal script subprocess returned error exit status 1
dpkg: trying script from the new package instead ...
main()
dpkg: error processing archive /var/cache/apt/archives/python3-debian_0.1.49_all.deb (--unpack):
new python3-debian package pre-removal script subprocess returned error exit status 1
File "/usr/bin/py3compile", line 323, in <module>
main()
File "/usr/bin/py3compile", line 302, in main
compile(files, versions,
File "/usr/bin/py3compile", line 185, in compile
for fn, versions_to_compile in filter_files(files, e_patterns, versions):
File "/usr/bin/py3compile", line 128, in filter_files
for fpath in files:
File "/usr/share/python3/debpython/files.py", line 71, in filter_public
for fn in files:
dpkg: error while cleaning up:
installed python3-debian package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Note that the error also occurs when directly connected (local terminal), not just via SSH.
Okay, I seem to have figured it out. This is actually caused by an issue in Ubuntu with different locales, but also affects my system for some reason.
I ended up manually applying the changes listed here and it fixed it. The file to edit is /usr/share/python3/debpython/files.py - just note that it differs slightly from the linked one, but the same additions/changes will work.
So you installed HA Supervised on Ubuntu? ![]()
No, I installed it on Debian. But the only mention of a similar issue I found was for Ubuntu, and the same fix transferred successfully to Debian.
An absolutely Amazing guide! Thank you so much I appreciate it very muchā¦
@Tamsy Million thanks for the upgrade guide, used successfully on Chinese NUC was running HA (in docker) + Supervisor on Debian 11 - now after upgrade running Debian 12. (All went smooth as butter, update took around 15 min overall)
when I execute the command ādpkg -i homeassistant-supervised.debā the system responds with a series of errors:
Are there any special reasons to install HA Supervised?
As stated in many places regarding the HA Supervised installation method:
This installation method is considered advanced and should only be used if one is an expert in managing a Linux operating system, Docker and networking!
Maybe you should reconsider and choose the Home Assistant Operating System (HA OS) instead?
However, running:
sudo apt install bluez cifs-utils nfs-common
before "dpkg -i homeassistant-supervised.deb" should do the trick.
thank you for your answer.
I tried to install bluez, but it seems it depends on several other installations.
The response of the system:
Exactly what distro are you using?
Debian 12.9, but I think itās time to take your suggestion and go back to HASSOS ![]()
Obiviously you did not strictly follow the OPās guide. Else you have already done this when reaching paragraph 2.1):
Furthermore you did this all as the root user where on the guide it is clearly stated to continue the installation as the unprivileded user you should have created the step before but get temporary root only by running sudo -i:
You should certainly do yourself a favor and go back to HA OS ![]()
Thanks!
After all the suffering, finally a solution that works! Thank you!
This also worked for moving from bookworm to trixie ![]()
I can also confirm update to trixie runs almost without problems. If you have MiniPC with N100 processor make sure having āpcie_aspm=off libata.force=noncq ahci.mobile_lpm_policy=1ā in grub cmdline. If you donāt do this, after reboot you will see a terrifying message about I/O errors on your SSD and a kernel panic.
Welcome to the forum, cortomalese.
Please be aware that the Supervised installation method has been depreceated by the end of last year.
More on the latter HERE.
Installing on a fresh install of Trixie running on a RaspberryPi 4B, the installation had two problems.
The resolve daemon, although was loaded, didnāt want to resolve any host name, so ā
wget get.docker.com failedā. Seems it was a dbus conflict, which a reboot fixed. -
While the supervisor was installing, I was met with a unresolved dependency: ā
Package nfs-common is not installedā, which a āsudo apt install nfs-common -yā couldnāt fix. I had to run āapt --fix-broken installā to successfully finish the installation and was then able to launch its web interface.
Thank you for the note ![]()
Not really.
As noted HERE (Addendum (12 Oct. 2024)) the below does the trick reliably:
If following the OPās guide by the book the following command instructs the latter:
which is found below Section 2 - Install OS Agent, Docker and Dependencies paragraph 2.1:
