Thank you so much for this. I installed this on a 120Gb SSD that boots on a Raspberry Pi 4 and it works perfect.
But the Home Assistant Core is on version 0.108.6.
I want to upgrade my home assist version but not to the latest one
Can you please help with a upgrade procedure to a specific version ?
Thanks a lot
Regards
David
Are you finding that HA device location doesn’t update? I keep getting my device trackers (from my phone) saying that I’m at home all the time. I switched to HassOS and everything works fine i would like to have access to Raspbian which I’m missing.
Also once you install this on PiOS are you finding that the pi sometimes freezes and you have to force reboot?
fixed. as i’m running phiole on this device as well, you need to make sure you have “listen on all interfaces” checked in the PIHole settings to enable internal traffic to get to the dns…
went through all the instructions and it said it was up and running. waited about 45 mins the port is still not up. any troubleshooting steps i can take?
seems like this just keeps repeating:
20-10-12 19:20:40 INFO (MainThread) [supervisor.plugins.dns] Setup CoreDNS plugin
20-10-12 19:20:40 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-10-12 19:20:45 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json: Cannot connect to host version.home-assistant.io:443 ssl:default [Try again]
Hello, thanks for your continued support. I was wondering if you can advise on installing duckdns and letsencrypt for exposing HA to internet. Would be great if you can point me to a tutorial which can work with this setup.
I have already installed and configured duckdns
Portforwarding is enabled.
I can access HA on internet but want SSL with it plz.
Hi, Thanks for the article. I have made a fresh installation this way on raspberry pi 3, I want know the location of configuration.yaml, how can I access it if I have made an ssh connection via ‘pi’ user to my raspberry.
my ultimate goal is to share a directory as media directory, I suppose by using media_dirs: media: /media recording: /mnt/recordings
most likely your config will be in /usr/share/hassio/homeassistant
You can check it in portainer, in the volumes section of the homeassistant container. Check the location in the column host/volume in the same line where you find /config
Hi
Thanks a lot for the guide, installed on pi os RPI4 2gb with 120gb ssd, working fine .
Is there any way to update the Addons latest version which are not available for update after this type(supervised “unsupported”?) of installation .?
i seem to have a problem with the installation. I am a complete noob with all of this just so you know.
I’ve followed the instructions and there weren’t any errors. The last thing I got after it was installed was:
[info] Home Assistant supervised is now installed
[info] First setup will take some time, when it’s ready you can reach it here:
[info] http://192.168.1.161:8123
The IP that this pi has should be 192.1.168.166 but when i tried both in my browser nothing showed up. I also tried to see what docker containers were running which were the following.
root@raspberrypi:~# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
d1a0ba096b21 homeassistant/raspberrypi3-homeassistant:landingpage "/init" 7 minutes ago Up 7 minutes homeassistant
42024a8c759c homeassistant/armhf-hassio-multicast:3 "/init" 9 minutes ago Up 9 minutes hassio_multicast
c61043910b65 homeassistant/armhf-hassio-observer:2020.10.1 "/init" 10 minutes ago Up 9 minutes 0.0.0.0:4357->80/tcp hassio_observer
03c9d836e3c3 homeassistant/armhf-hassio-cli:2020.10.0 "/init /bin/bash -c …" 12 minutes ago Up 11 minutes hassio_cli
4300007465cf homeassistant/armhf-hassio-audio:17 "/init" 13 minutes ago Up 12 minutes hassio_audio
ea461ff08ffd homeassistant/armhf-hassio-dns:9 "/init coredns -conf…" 15 minutes ago Up 15 minutes hassio_dns
a69c0f137c8c homeassistant/armhf-hassio-supervisor "/init" 18 minutes ago Up 17 minutes hassio_supervisor
Is it true that there isn’t a open port for the landingpage or any port containing 8123.
I hope someone can help me further with this.
*after I made this reply i looked into the active devices on our network and I noticed that there are now 2 raspberry pi’s showing with the IP ending in 166 and 161
