Installing Home Assistant Supervised using Debian 12
Copy the (hidden) .storage folder from the config folder.
FYI: this .storage folder holds all devices and entities.
You might also want to include the yaml files you want to keep (configuration, automation, groups, scenes, scripts, secrets)
Paste everything back into the new setup (using the Samba addon) and reboot :wink:
thanks a lot i’ll try that :slight_smile:
@kanga_who Debian 11 installation links are not valid not - the first link goes to Debian 12 image and the full image link returns 404 (the following text found also - Unofficial non-free images including firmware packages. UPDATE 10 Jun 2023: As of Debian 12 (Bookworm), firmware is included in the normal Debian installer images. USERS NO LONGER NEED TO LOOK FOR SPECIAL VERSIONS).
What should be used now?
As for now until HA Supervised fully supports Debian 12 (“Bookworm”) you can use the following links:
@Tamsy, can not get it working with Debian 12.
dpkg -i homeassistant-supervised.deb fails, no dependencies are found (systemd-journal-remote, systemd-resolved). When I try to resolve it with apt-get -f install, it fails at
1. [info] Restarting NetworkManager
2. [info] Set up systemd-journal-gatewayd socket file
3. [info] Enable systemd-journal-gatewayd
see the full log at pastebin.
As mentioned HA Supervised does not yet support Debian 12. If you get HA up and running you will get an “Unsupported Installation”.
Either install Debian 11 (“Bullseye”) for now or wait for HA 2023.7.x which as rumor says will support Debian 12.
ah, thanks. I’ve read your message incorrectly initially.
Are you sure about that? :slight_smile: I just checked (for an answer in another thread), and it says Debian 12 is supported for Supervised install…???
See here:
Arcording to this writing (19h ago): “[…] for now yes unsupported OS so unsupported system […]”
Strange, isn’t it? But in doubt I don’t believe the documentation, I’d rather go with someone who tried it… :rofl:
Exactly my thinking too :grin:
There is no update mechanism for updating the homeassistant supervised deb or the os agent deb. You need to make sure you have the latest when trying stuff.
I have installed vanilla Debian-12 ob RPi4 and installed HA Supervised.
Does anyone know how I can overclock the PI4B when it is running vanilla Debian?
I have tried adding the overclocking params in /etc/default/raspi-firmware-custom, but they do not seem to have any effect.
Usually /boot/config.txt
You can just install the new version over the top. I have done os-agent multiple times to make sure I was running latest and due to a new bunch of HA instigated incompatibilities I just reinstalled the requirements and ran the deb script file again just a few days ago.
Yes of course, but my point is that it is not just a one-off set-and-forget.
Chicken and egg :
I have HAS installed on Debian 12 but ends up with “Unhealthy system - Not privileged”.
I can not install “Advanced SSH & Web Terminal” because : “AddonManager.install’ blocked from execution, system is not healthy - privileged”
Any clue ?
rerun supervised installer could help
You can also set it to ignore the health check
For those who just want to upgrade from Debian 11 (bullseye) to Debian 12 (bookworm) check out my upgrade guide here. The guide is also valid for x86_64-devices.
