ngocdung@Linix:~$ sudo apt-get --allow-releaseinfo-change update
Ign:1 http://deb.debian.org/debian bookworm InRelease
Ign:2 http://security.debian.org/debian-security bookworm-security InRelease
Ign:3 http://deb.debian.org/debian bookworm-updates InRelease
Err:2 http://security.debian.org/debian-security bookworm-security InRelease
But you have a connection? Does ping security.debian.org
work?
ngocdung@Linix:~$ ping security.debian.org
ping: security.debian.org: Temporary failure in name resolution
ngocdung@Linix:~$ ping google.com
ping: google.com: Temporary failure in name resolution
See, you have a network problem. DNS name resolution or so.
Is your network config okay?
Permanent IP address or DHCP? Whatās your DNS?
Edit
I will be off for a while, check out this too:
https://www.turnkeylinux.org/forum/support/tue-20230718-0732/debian-12-template-error-message
Could you solve the problem?
I test it on my new machine and so far no luck in not making NetworkManager replace my new resolv.conf
. It works however, resolv.conf
is not 100% right since it shows a double nameserver. Maybe anyone has the same issue and knows how to fix this?
At the moment I remove the link of resolv.conf
and replace it with resolv.conf
of the original installation.
Upon HA running the ping become very slow and intermittent (unsure what I did wrong) maybe someone can give some light? I also did /etc/systemd/resolved.conf
as suggested by @SkynetNexus which solve the internet access problem.
At this point however HA running in the background
My next hurdle is restoring a backup, in my case upon restoring a full backup, the screen goes back to the register and nothing seems to be restoring. Iām not sure whether Iām expecting a fast response or if I should wait 20 minutes.
This is off topic, but nevertheless: wait. Restoring takes a long long time
Have you checked my post here?
Revert the changes suggested by SkynetNexus and try the possible solution I provided.
Yeah I didā¦ changing that did not work at all and I canāt ping out from my VM
Why are you running this as a VM?
Unfortunately you did not strictly follow this guide.
My current machine Proxmox runs Debian 12 Bookworm ā VM, so you are telling me this canāt run supervised? Am I lost somewhere?
which part of the guide? Iām running Debian 12 on proxmox which running i7 intel. r u saying this will not be able to run supervised?
This guide is not for Proxmox.
Secondly, why would you run a Debian VM and then install Supervised when you can much more easily run a HA OS VM?
This guide is for installing Home Assistant Supervised using Debian 12 on a bare metal machine but not for running HA Supervised on Proxmox.
A little search would have brought you to i.e.
Installing Home Assistant OS using Proxmox 8
or to i.e. -
How To Install Home Assistant on Proxmox: The Easy Way
or to i.e - How to Install Home Assistant on Proxmox
and so many moreā¦
Well, running supervised version on proxmox give u more in terms of going into the machine, unlike HAOS. Which on Debian 11 have no problem.
For what purpose though?
The point of running a Hypervisor like Proxmox is that you can deploy multiple CTs or VMs making it unnecessary āgo into the machineā.
I must admit I do this too on a dev machine. Yes I hate HAOS that much and like to run bash scripts etc and non approved docker containers.
I do the same on my test machine, but as a daily driver there is absolutely no need to run Supervised in a VM if you are using Proxmox. Itās completely redundant.
For someone like yourself @DavidFW1960 who knows their way around these sorts of things itās not an issue, but adding extra layers into a system for someone who doesnāt have the skill set or knowledge around how to solve issues just isnāt necessary.
Iāve been using HA OS myself for a number of years in a Proxmox VM and just run CTs and VMs for anything else, keeps things nice and simple.
