Installing Home Assistant OS using Proxmox 8
Thank you for this guide. Just used this guide to switch my HA OS install from a rasperry pi to a dell optiplex 3020m I purchased on ebay. Worked like a charm and got HA up an running with everything restored in short order. I had zero experience with Proxmox and the only area I stumbled on was the username for SSH and web interface. Once I figured out the username was “root” for the password I created in the Proxmox setup I was off to the races.
Now to figure out what to do with the rest of the resources available on the 3020m and my unused Rpi.
Whiskerz007 has a great lxc script, Debian base that is supported. (doesn’t say “You are running an unsupported installation” )
Forgot to mention, it has the Supervisor/Add-Ons
Nice, thanks for the Info!
It’s interesting because the devs have stated the LXC container is definitely not recommended or supported and will cause problems.
I’ve heard the same. I’ve been running it since it was created without any problems, and will continue until those said problems exist :slightly_smiling_face:
Following the guide I run into problems with the Hass.io VM. It does not get an IP-adress. The guest deamon(?) does not start. Any pointers?
Hi. I’m running into the same problem. The guest won’t start.
@MWheeler72 and @Poppe, I’ve run the install script on an existing Proxmox install and can confirm it works as it should and have a new HA VM up and running with IP in under 5 mins.
I would suggest you either have a network problem, or, that you have not set up Proxmox correctly during the install process.
Check to make sure the VM has a MAC address… that did happen to me once. Once I set a valid MAC address all was well. Check in your router as well to make sure DHCP is allocating an IP Address…
Good idea :+1:
Hey, I am getting the same Guest Agent not running. Set up tonight following the guide. I have an IP and Mac for proxmox in my Unifi clients.
The Hassosova-4.15 Mac even shows up in the Unifi client list. I tried to assign it a static IP in Unifi, but I cannot connect to the Home Assistant web interface.
I am very new to proxmox so I could have a config issue, but I am not sure what.
A quick Google shows this for Proxmox guest agent. Have a read through this page and see if anything helps.
https://pve.proxmox.com/wiki/Qemu-guest-agent
I looked at that before, but since you brought it up again I gave it a shot.
Probably beyond the scope of this thread, but I installed that in proxmox through ssh and when I try to start the guest agent I get errors.
Journalctl gives me the following:
Oct 31 21:40:14 pve pvedaemon[24113]: VM 100 qmp command failed - VM 100 qmp command 'guest-ping' failed - unable to connect to VM 100 qga socket - timeout after 31 retries
From the article you linked it seemed to me like the guest agent needed to be installed into the VM, but I don’t have a clue as to how to go about that.
When I open the Home Assistant VM console (shell I guess) it does not accept apt-get.
Proxmox says the VM is running, I just cannot access it.
What do you get when you run this in Proxmox?
qm agent <id> ping
root@pve:~# qm agent 100 ping
QEMU guest agent is not running
Have you tried to stop, then restart the HA VM?
It doesn’t respond to reboot or shutdown commands. I have been resetting it. Not sure if that is the right thing to do.
Edit: Probably because the guest agent isnt running so the VM doesn’t respond to ACPI commands.
Perhaps delete the VM altogether, then in Proxmox run;
apt-get install qemu-guest-agent
systemctl start qemu-guest-agent
then re-run the installer script
sudo bash -c "$(wget -qLO - https://github.com/whiskerz007/proxmox_hassos_install/raw/master/install.sh)"
moxmanager@pve:~$ sudo apt-get install qemu-guest-agent
[sudo] password for moxmanager:
Reading package lists... Done
Building dependency tree
Reading state information... Done
qemu-guest-agent is already the newest version (1:3.1+dfsg-8+deb10u8).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
moxmanager@pve:~$ sudo systemctl start qemu-guest-agent
A dependency job for qemu-guest-agent.service failed. See 'journalctl -xe' for details.
moxmanager@pve:~$ sudo journalctl -xe
Oct 31 22:11:00 pve systemd[1]: pvesr.service: Succeeded.
-- Subject: Unit succeeded
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- The unit pvesr.service has successfully entered the 'dead' state.
Oct 31 22:11:00 pve systemd[1]: Started Proxmox VE replication runner.
-- Subject: A start job for unit pvesr.service has finished successfully
-- A start job for unit pvesr.service has finished successfully.
-- The job identifier is 105419.
Oct 31 22:11:07 pve systemd[1]: dev-virtio\x2dports-org.qemu.guest_agent.0.device: Job dev-virtio\x2dports-org.qemu.guest_agent.0.device/start timed out.
Oct 31 22:11:07 pve systemd[1]: Timed out waiting for device /dev/virtio-ports/org.qemu.guest_agent.0.
-- Subject: A start job for unit dev-virtio\x2dports-org.qemu.guest_agent.0.device has failed
-- A start job for unit dev-virtio\x2dports-org.qemu.guest_agent.0.device has finished with a failure.
-- The job identifier is 105346 and the job result is timeout.
Oct 31 22:11:07 pve systemd[1]: Dependency failed for QEMU Guest Agent.
-- Subject: A start job for unit qemu-guest-agent.service has failed
-- A start job for unit qemu-guest-agent.service has finished with a failure.
-- The job identifier is 105274 and the job result is dependency.
Oct 31 22:11:07 pve systemd[1]: qemu-guest-agent.service: Job qemu-guest-agent.service/start failed with result 'dependency'.
Oct 31 22:11:07 pve systemd[1]: dev-virtio\x2dports-org.qemu.guest_agent.0.device: Job dev-virtio\x2dports-org.qemu.guest_agent.0.device/start failed with result 'timeout'.
Oct 31 22:11:07 pve sudo[2306]: pam_unix(sudo:session): session closed for user root
Oct 31 22:11:17 pve sudo[2545]: moxmanager : TTY=pts/0 ; PWD=/home/moxmanager ; USER=root ; COMMAND=/usr/bin/journalctl -xe
Oct 31 22:11:17 pve sudo[2545]: pam_unix(sudo:session): session opened for user root by moxmanager(uid=0)
lines 3713-3748/3748 (END)
Have you checked to confirm your apt source list is correct as per section 2.3 of the guide? Just wondering if it’s a dependency issue from Proxmox not updating. I may be completely wrong, but worth checking.
