Hello!
I’m trying to install Home Assistant in a Lima VM. I used to have it running well in a VM running under UTM but since Lima is also QEMU and seems to run a little bit snappier, I thought of migrating.
I create a Debian 12 machine and follow the instructions for the supervised installation.
All goes well during the install but eventually things don’t work properly.
Using the observer I see there’s an issue with the network manager
I am using the shared network interface from Lima using socket_vmnet (Network | Lima). Things seem to work but I get a bunch of errors related with the supervisor:
23-10-23 15:02:55 WARNING (MainThread) [supervisor.dbus.agent] Can’t connect to OS-Agent
23-10-23 15:03:05 WARNING (MainThread) [supervisor.utils.dbus] Busy system at de.pengutronix.rauc - /
23-10-23 15:03:18 WARNING (MainThread) [supervisor.utils.dbus] Busy system at de.pengutronix.rauc - /
23-10-23 15:03:31 WARNING (MainThread) [supervisor.utils.dbus] Busy system at de.pengutronix.rauc - /
23-10-23 15:03:34 ERROR (MainThread) [supervisor.utils.dbus] Could not get introspection data after 3 attempts
23-10-23 15:03:34 WARNING (MainThread) [supervisor.dbus.rauc] Can’t connect to rauc
23-10-23 15:03:34 WARNING (MainThread) [supervisor.resolution.evaluations.base] NetworkManager is not correctly configured (more-info: Network Manager - Home Assistant)
23-10-23 15:03:34 WARNING (MainThread) [supervisor.core] System running in a unsupported environment!
Any idea of what might be happening here? Anyone else running HAOS on Lima?
Thanks a lot for the support!
