Surprisingly it works fine, HA starts ok - it seems like it should work, however the ability of HA to perform a ‘detection’ against the entire network, appears to be unfortunately failing.
I have 6 libreelec boxes. I am on team Kodi and a moderator on the le forum. I don’t have any on a pi.
I was trying this out with various incarnations of the docker command line without a lot of success. I am getting zeroconf errors.
I am not a docker expert. I am not a zeroconf expert. I imagine zeroconf needs to use a set of ports that will already be allocated to Kodi. Just guessing here.
This is my home assistant log for one run. I think the solution will be to exclude default_config from configuration.yaml and include what is needed as a minimum.
2019-08-16 19:27:11 ERROR (MainThread) [homeassistant.setup] Error during setup of component zeroconf
File “/usr/src/app/homeassistant/setup.py”, line 172, in _async_setup_component
component.setup, hass, processed_config # type: ignore
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/src/app/homeassistant/components/zeroconf/init.py”, line 61, in setup
zeroconf = Zeroconf()
File “/usr/local/lib/python3.7/site-packages/zeroconf.py”, line 1807, in init
self._listen_socket = new_socket()
File “/usr/local/lib/python3.7/site-packages/zeroconf.py”, line 1778, in new_socket
s.bind((‘’, port))
OSError: [Errno 98] Address already in use
2019-08-16 19:27:11 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: zeroconf
2019-08-16 19:27:11 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
Oh wow, ok geez! Ok thanks man. Well that’s definitely going to be super helpful with my problem.
I can’t for the life of me, recall WHY I need zeroconf for kodi but I’m fairly sure it’s quite important (might be using my Kodi Android / iOS remote app?)
