Installing on Android
Hi, i loaded the Home Assistant app on my android phone but i can’t get past the “What is your Home Assistant URL?” section!
Where/how do i find this url?
What does the browser window say on your computer.
That is the URL.
But if this is just a local IP then it won’t work outside your wifi coverage
Hi, im actually using the android app so there is no url or browser window. What do i need to do?
Not the phone. Computer where you are viewing HA normally
The app in your phone is just an interface for a Home Assistant instance installed elsewhere. It is not Home Assistant itself.
You need to install Home Assistant somewhere else.
Please excuse my ignorance but this is abit too techie for me to fully understand.
What do you mean by ‘on my computer’?
Do i need to install something on my laptop? If so can i install it on my working laptop that i use daily?
It is possible. But if you want Home Assistant to work fine, your laptop has to run 24/7.
Better is to install it on a dedicated minicomputer, like Intel NUC or a Raspberry Pi, which can stay allways on and uses very low power.
OK i understand.
Can you recommend a dedicated microcomputer to install it on, other than a Raspberry PI, that is quiet or fanless?
Have a look at this video:
Would a thin client work?
Yes, I’m running my setup on a thin client with intel Celeron processor.
What is the spec of your thin client?
