gr4z
(gr4z)
1
OK I have followed the guides on here, all very straight forward. Installed Python 3.5.2 and then used
pip3 install homeassistant
It reports it has installed homeassistant. However, I come to run hass and get
-bash: hass: command not found
I have rebooted, reinstalled python. Nothing works. I am pulling my hair out with something so trivial. Anyone suggest a solution?
treno
(travis reno)
2
try : /Library/Frameworks/Python.framework/Versions/3.5.2/bin/hass
If that works, you just need to add /Library/Frameworks/Python.framework/Versions/3.5.2/bin to your PATH
gr4z
(gr4z)
3
Life saver. Thanks! If I knew how I would update the docs as it really should mention that along with not using Python 3.6.
