Im trying to install Home Assistant OS an an ASRock Beebox N3000.
This Box was running hass supervised for quite some time. I want to switch to hass OS because this box will be dedicated to hass after moving other services to another machine.
I downladed the NUC image and flashed to USB drive using Rufus (also tried with etcher).
When trying to boot to USB I get a black screen with a non-blinking cursor in the top left corner.
The N3000 is x64, so I guess the NUC image is the correct one?
I didn’t mention earlier that i can’t flash the disk that easily, since it’s an m.2 drive and this is the only machine i have with m.2 slot.
So what i did was basically like you said, but from a live system.
Starting a KDE live USB, install etcher, download image and flash system disk from live system.
I got kinda confused when reading the instrcutions on the website, wondering why installing the OS is kinda skipped, but that makes sense now
