My goal is to run atvremote to configure/install the apple tv component. See instructions here.
In the terminal have the following code:
pip3 install --upgrade pyatv
and the following error:
pip3: command not found
What i did was adding a symbolic link to my /usr/local/bin/ directory:
ln -s /volume1/@appstore/py3k/usr/local/bin/pip3 /usr/local/bin/pip3
So far so good. But when I try to install pyatv
which is needed to run atvremote I get this error:
Collecting cffi>=1.7 (from cryptography>=1.8.1->pyatv)
Using cached cffi-1.10.0.tar.gz
Complete output from command python setup.py egg_info
No working compiler found, or bogus compiler options passed to the compiler from Python's distutils module. See the error messages above. (If they are about -mno-fused-madd and you are on OS/X 10.8, see http://stackoverflow.com/questions/22313407/ .) ----------------------------------------
Command python setup.py egg_info failed with error code 1 in /tmp/pip-build-nooxy3bi/cffi/
It seems that it has something to do with a compiler. Did anyone fix this error? Any help is greatly appreciated :-).
Just for information. I’m running homeassistant on a Synology DS414.
