Installing python3 and pip for an integration
Hi there. First post and first timer here.
I’ve got HAOS installed on a local RP4 with things like Google devices, Tuya smart plugs, Hikvision DVR and the following add-ons installed:
I can access via SSH ports 22 and 22222:
As well as via docker:
docker
As someone not experienced in containers/docker, can someone advise if it is actually possible to get this integration up and running?
home-assistant io/integrations/simplisafe
simplisafe-python.readthedocs io/en/latest/intro.html
I’m struggling to get my head around the HAOS architecture to understand if and where I need to install python3, pip and simplisafe-python (simplipy).
Some threads say you can use extra repos and add-ons to achieve this, some say I should re-install with Supervised, some are out of date etc.
Hope you can help.
You would do that on another computer, not on HAOS.
insert facepalm gif here
I thought it was a dependency :joy: That’s good news as I can just do that on one of my Linux VMs then. Thanks Tinkerer.
Worth noting, doing this on a remote Linux VM won’t take you to a webpage when hitting enter
Ended up just using the built-in integration link to the login page, logging in, grabbing the code from the Developer Tools > Console and putting that in the Authorization Code box. This picked up all my SimpliSafe devices in HA.
