Hi, I have a reolink E1 zoom camera. I tried installing the Reolink IP camera integration in Hacs it things for a second and then it does nothing. It does not install. Does anyone have a solution for this?
thanks
thanks
If it installed via HACS it has its own github repository where issues belong
Ok, thanks. I thought somebody here maybe had the same and could point me to a solution.
Where in HACS is the Reolink IP camera … I cant find it via the search function in HACS
From HACS main page, naviagte to settings, and where it says “add custom repository” put “https://github.com/fwestenberg/reolink
Nick… I have no such page… Selecting the HACS from my menu
Where It has no " Settings"
<<< EDIT>>
Ahh top right corner… then I get…
hacs -> integrations
Lower right corner is + Explore & Add Repositories. Click it. Find Reolink.
You haven’t installed the repo have you?
EDIT because of the red on black I missed the error message Repostitory structure for v0014 is not compliant
in your post. Upon further investigation it looks like https://github.com/fwestenberg/reolink is not a custom component at all, it is a python script to access reolink. (I knew I shouldn’t have copy/pasted a solution from another thread without checking, sorry 'bout that).
Got it.
Use this url for HACS https://github.com/fwestenberg/reolink_dev
Looks like @fwestenberg has split his repo
Nick…that was it!
Which version is the most stable?
Thanks everyone!!!
Next question… How do I fill out this…
Is there one for each camera… Or do I need to drop into yaml and configure each camera as an entity
Hello, how are you? Good year.
I managed to install the Reolink IP camera in the hack. But it does not appear in the integrations
Supervisor
Version
2020.12.7
It takes some time. I also thought it was not working. After a day or so I tried again and saw the integration. A restart might help also.
This is third party software, post an issue on their github.
How did you get to this options screen. I cannot work out how to set anything up in the latest version?
This is a custom component, why not post on the author’s github?
It took a couple of times trying to add the integration for it to work… it was a PITA… but once I got it installed its been working just fine…
Just wait til you use the app then come back to this integration. The stream won’t work anymore. I dropped this integration for a normal stream. Not to mention, half the time the stream stopped working all together without external app use.
