My house has ceiling heights ranging from 2.70m /9ft to 3.70m / 12ft high excluding one area where they go up 6m / 21ft. I tend to install many of my sensors up high out of reach, often attaching them magnetically to HVAC vents on the ceiling. While this works great (except for temperature measurement as the proximity to the vent affects the measurement), I really don’t like having to get the ladder out each time I need to reset it or change a battery. Yeah… the marketing blah blah saying the battery lasts years is just nonsense in most cases.
I’ve been using a light bulb remover like this:
But putting them back up is not as simple… it just dawned on me that there must be long reach “grabbers” and found some on amazon. The problem is that most are meant for elderly to reach something on the floor, while I need to reach just under 2m / 6ft above my head in the highest areas.
This is a “pro” one all of metal that I liked but is a bit too short:
I found some really cool fruit harvesters that are long enough but the cost is 10x that of grabbers for elderly.
I am sure lots of you have the same issue… did you find a solution? My ideal would be something I can screw on at the end of a painter’s extension pole to avoid having yet another single use tool… but I am open to just getting a grabber as I am having to reach for these sensors way too often.
