I am trying to install samba from the hassbian-config but I will not succeed, can anyone help me how to install samba? It looks like this
pi@hassbian:~ $ sudo hassbian-config install samba
Samba install script for Hassbian
Copyright(c) 2017 Fredrik Lindqvist <https://github.com/Landrash>
Running apt-get preparation
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Hit:2 http://mirrordirector.raspbian.org/raspbian stretch InRelease
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
hassbian-scripts : Depends: cython3 but it is not going to be installed
samba : Depends: python-dnspython but it is not going to be installed
Depends: python-samba but it is not going to be installed
Depends: samba-common (= 2:4.5.8+dfsg-2+deb9u2) but 2:4.5.8+dfsg-2+deb9u1 is to be installed
Depends: samba-common-bin (= 2:4.5.8+dfsg-2+deb9u2) but it is not going to be installed
Depends: tdb-tools but it is not going to be installed
Depends: update-inetd but it is not going to be installed
Depends: libldb1 (>= 0.9.21) but it is not going to be installed
Depends: libtdb1 (>= 1.2.7+git20101214) but it is not going to be installed
Depends: libtevent0 (>= 0.9.16) but it is not going to be installed
Depends: libwbclient0 (= 2:4.5.8+dfsg-2+deb9u2) but 2:4.5.8+dfsg-2+deb9u1 is to be installed
Depends: samba-libs (= 2:4.5.8+dfsg-2+deb9u2) but it is not going to be installed
Recommends: attr but it is not going to be installed
Recommends: samba-dsdb-modules but it is not going to be installed
Recommends: samba-vfs-modules but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Adding homeassistant Samba user
sudo: smbpasswd: command not found
Adding shared folder for Home Assistant configuration directory
patching file smb.conf
Restarting Samba service
Failed to restart smbd.service: Unit smbd.service not found.
Installation done.
If you have issues with this script, please say something in the #Hassbian channel on Discord.
Configuration is now available as a Samba share at \\10.0.1.4\homeassistant
pi@hassbian:~ $
Trying to install Samba to allow editing of configuration scripts remotely. I’m getting this error when using command prompts mentioned in your post’s link:
Hi, I’m having kind of the same problem
I can do everything using Putty, but on my windows 7 PC I do see my RP as a computer, but cannot open it.
Samba installed
RP connected by WiFi
Done everything mentiont above
It dit work yesterday connected over Eth, but wanted to use it over WiFi. Dit a clean setup of Hassbian (got a RB 3+).
