Hi, I could not open web ui after configurator install, error in the log file.
any ideas.
regards christian
You probably enabled SSL (it is by default) while not providing the certificate. Either do that or set ssl to false.
Thanks ,
have put ssl false and now the configurator works.
What happens if ssl is false / true, later in home assistant configuration, is it possible to change later?
