I’m feeling a little bit like a crazy person here… I see everyone doing cool things with the custom button card, but the link in the installation to button-card.js is broken, and I don’t see that file anywhere. How do I actually install it?
Manual Installation
- Download the button-card
Note that this is a direct link to the .js file. Most browsers won't load this if you just click on it. You need to right-click and do a "save as". Then follow the rest of these directions. - Place the file in your
config/wwwfolder - Include the card code in your
ui-lovelace-card.yaml
title: Home resources: - url: /local/button-card.js type: module
- Write configuration for the card in your
ui-lovelace.yaml
Installation and tracking with hacs
- Make sure the HACS component is installed and working.
- Search for
button-cardand add it through HACS - Add the configuration to your
ui-lovelace.yaml
resources: - url: /hacsfiles/button-card/button-card.js type: module
- Refresh home-assistant.
I used the HACS method to install.
I already linked directly to what you’ve just copied and pasted here… this doesn’t address my question.
When you said the link was “broken”, I assumed you meant that the link went nowhere or to someplace it shouldn’t. (That’s the textbook definition of a broken link.)
I checked the link and it downloaded a .js file that is in fact identical to the .js file in your corrected link.
I thought possibly that you had the same result I did when I simply clicked on the link. (It was blocked by my anti-virus.) So I added the explanation of doing a save-as to bypass that apparently-does-nothing result.
At this point, I’m not at all sure why you had a problem with the original link.
However, you did exactly what folks should do, if they link in a github readme doesn’t appear to work: Go looking through the github for the latest release and download that. I should have included that in my earlier response. I’m glad that worked for you.
I cant see to get the button-card.js working. Any thoughts?
I have
-added the button-card.js to my www folder and added it to resources:
-tried to install the HACS button-card but it just spins (never installs)
-rebooted several times…
Here is my dashboard
title: Tablet
# Include external resources
resources:
- url: https://cdn.jsdelivr.net/gh/bramkragten/weather-card/dist/weather-card.min.js
type: module
type: module
- url: /community/button-card/button-card.js
type: module
# Optional background for all views. Check https://developer.mozilla.org/en-US/docs/Web/CSS/background for more examples.
background: center / cover no-repeat url("/background.png") fixed
# Exclude entities from "Unused entities" view
excluded_entities:
- weblink.router
- icon: mdi:home-assistant
cards:
- type: vertical-stack
cards:
- type: 'custom:button-card'
entity: light.living_room_lamp
icon: mdi:light-bulb
color: rgb(28, 128, 199)
state:
- value: 'off'
color: rgb(255, 0, 0)
My lovelace view says “Custom element doesn’t exist:button-card”
Use one entry:
/local/community/button-card.js
P.S. Or - if the .js file is in a additional folder:
/local/community/button-card/button-card.js
That did not work… It still says “Custom element doesn’t exist: cutton-card”
There are files in “\www\community\button-card” button-card.js & button-card.js.gz
You only need the .js file. The second one is the zipped version.
Which yaml mode is this in your code above?
From a seperate dashboard…
dashboards:
lovelace-generated: # Needs to contain a hyphen (-)
mode: yaml
filename: ui-office_tablet.yaml
title: Office Tablet
icon: mdi:tablet-dashboard
show_in_sidebar: true
require_admin: false
Ok. So when you use yaml mode then you should put the ressources in the config file:
https://www.home-assistant.io/lovelace/dashboards/#adding-more-dashboards-with-yaml
and I did have it there just in case here is the entire lovelace part…
lovelace:
mode: yaml
resources:
- url: /local/my-custom-card.js
type: js
- url: /local/my-webfont.css
type: css
- url: /local/vertical-stack-in-card.js
type: js
- url: /local/Home-Assistant-Mail-And-Packages-Custom-Card-master/mail-and-packages-card.js
type: js
- url: /local/grid-layout.js
type: js
- url: /local/layout-card.js
type: js
type: module
- url: /local/community/button-card/button-card.js
type: js
#https://github.com/mattieha/slider-button-card
- url: /local/slider-button-card.js
type: js
# - url: /local/custom_ui/weather-card.js
# type:
dashboards:
mode: yaml
So why do you repeat them in your dashboard? Sure, that this is correct?
Ok, after a whole bunch of cleanup it would not work, but found a page that shows to clear cache (ctrl+R) and that worked.
Thanks for your help!!!
Obviously the HACS install method is still broken as there is no way i can install via HACS.
I edited the Dashboard as below but still gives an error … i wonder if url is ok
title: Home
resources:
type: module
However looking into configuration → resources its listed as HACS Resource
/hacsfiles/button-card/button-card.js?hacstag=xyz
You don’t need those resources statements in the dashboard file at all.
The only place you need them is in configuration.yaml as follows:
lovelace:
mode: yaml
resources:
type: module
Thank you sir.
This was what I needed to do to get it to work.
buonasera bohème61, ti scrivo in italiano perche forse è piu facile la traduzione per te…
sono un neofita e vorrei installare button-card per comandare il mio telecomando, almeno per cominciare, potresti aiutarmi nell’installazione, ti avverto e da meno di due settimane che opero su homeassistant, ho capito che dovrei scaricare il file da github perche su hacs non la vedo.
te ne sarei grato se mi volessi aiutare. GRAZIE
Hej Snawork , det ville være lættere for mig at oversætte fra engelsk, Dansk eller Svensk ... ![]()
Here is the "manual installation guide"
Manual Installation
# title: Home
# resources:
# - url: /local/button-card.js
# type: module
ui-lovelace.yaml
But as you see in the overall guide, there is a lot configuration effort, and i cant help you there, as im also quite new to HA since November ( but i found it in HACS, as i recall
) but maybe it was in a custom-repository, not in default HACS-repository , so if you are new(2 weeks experience in HA) i suggest you wait with trying to configure your remote-control
Here is the repository on Github
If you decide to download it from Github, you follow above procedure, and restart HA, then you have to create a "custom" Lovelace.Yaml file ( as well as adding url: to this in your /config/configuration.yaml ) , as you should not edit your default Lovelace (frontpage) or other you might have created via "Manage Dashboard"
I have so far only created 4 UI Controlled Dashboards, no "dashboard.yaml" ui-lovelace.yaml , and when it comes to "Button-design" are my needs so far limited style/size etc, a lot of this can you accomplice by "merging" cards ... actually i just got my Android TCL-TV remote into AQARA-Hub-M2( IR- Controller ), 2 days ago, but it doesnt show up in HA, "Homekit"-aqara integration, all other Aqara/xaumi devices i have work perfect in HA , so far i can only use my phone-ap for this TV-remote , and/or certain functions through Google-Home/assistant ... beside i have alot more important stuff
to integrate and automate, than my tv-remote.
If it's only a "Button" you are looking for, there are other cards ( and as i said can you test which "funktions" you can merge from other cards..
example:
multi-entities-card
custom:slider-button-card
and place then in layout-cads
or grid
Wish you good luck .. BR Jørgen
Grazie mille per la tua gentilezza, ti auguro buona serata, spero di riuscirci. A presto pasquale
