I’m having issues with time based data from Grafana and it appears there is an issue with time zones. It appears the MariaDB I use for both the HA config DB and a separate DB holding some other data is not configured for handling time zones…
Now, it appears this is rather important for something handeling time series data, i.e. most everything HA…
So, as per Time Zones - MariaDB Knowledge Base these tables are empty and I should install them using this tool mysql_tzinfo_to_sql - MariaDB Knowledge Base
Now… here starts my problems…
How do I do that?
I tried to SSH but that didn’t work. The command does not appear to be there (I’m guessing the files are there, but can’t be found)
Anyone have a step-by-step for a Linux illiterate?
Thanks in advise
