Installing Wazuh agent on Home Assistant
Hi, I need to run the below account on HASS. I can’t seem to get it right from the command line. But not sure how I do this as this as HASS is the the Ubuntu install that I am used to.
wget https://packages.wazuh.com/4.x/apt/pool/main/w/wazuh-agent/wazuh-agent_4.7.4-1_amd64.deb && sudo WAZUH_MANAGER='ip-address' WAZUH_AGENT_NAME='hass' dpkg -i ./wazuh-agent_4.7.4-1_amd64.deb
HA OS ? Can’t do. HA OS is built on Buildroot, not Debian, so can’t install .deb packages.
and other advice…
A note to remember for the future. As a new Home Assistant person you probably wouldn’t know this. The term HASS means hate in German, so the Home Assistant Project has not used that anywhere a customer will see it for 4 or 5 years. There are some internal code references that have not been converted yet and that gets fixed as things are edited.
Thanks for the heads up; noted and apologies if any offense was cause.
No offense, just being a friendly resource as you have no way of knowing that.
What kind of packages CAN it install?
You can install .apk packages in the Home Assistant container, but you have to reinstall them after each HA update, so not recommended.
