Installing zigbee2mqtt (Failed to start EZSP layer with status=HOST_FATAL_ERROR)
Hello, I’ve been stuck for several days and I can’t find a solution despite a lot of searching.
I will try to summarize my installation/configuration as much as possible!
Hardware, I’m running DSM Synology, home assistant is in a docker container.
The whole thing is installed with a docker-compose with home assistant, mqtt which has already been running for quite some time for other hardware, fileeditor, esphome and nodered!
So I added zigbee2mqtt (koenkk/zigbee2mqtt) to docker-compose.
I have a Sonoff ZBBridge Pro Zigbee Gateway (ZBBridge-P) that I reset which worked perfectly under ZHA (completely uninstalled) with multiple devices.
Here is the z2m configuration.yaml:
homeassistant: false
frontend: true
mqtt:
  base_topic: zigbee2mqtt
  server: 'mqtt://localhost:1883'
  user: l****t
  password: K*****8
serial:
    port: 'tcp://192.168.1.171:8888'
    adapter: ember
    zigbee_herdsman_debug: true
advanced:
  network_key:
    - 152
    - 57
    - 224
    - 63
    - 140
    - 156
    - 158
    - 21
    - 252
    - 36
    - 255
    - 77
    - 62
    - 67
    - 141
    - 198
  pan_id: 4038
  ext_pan_id:
    - 204
    - 169
    - 144
    - 92
    - 184
    - 180
    - 162
    - 152
The part of my docker-compose:
#zigbee2mqtt
version: '3.8'
services:
  zigbee2mqtt:
    container_name: zigbee2mqtt
    image: koenkk/zigbee2mqtt
    restart: always
    volumes:
      - ${RACINE}/zigbee2mqtt/data:/app/data
      - ${RACINE}/zigbee2mqtt/run/udev:/run/udev:ro
    ports:
      - 8888:8080
    network_mode: bridge
    environment:
      - TZ=Europe/Paris
And the log via Portainer of zigbee2mqtt not wanting to launch:
Using '/app/data' as data directory
[2024-06-10 05:13:34] info: 	z2m: Logging to console, file (filename: log.log)
[2024-06-10 05:13:34] info: 	z2m: Starting Zigbee2MQTT version 1.38.0 (commit #fe048e6)
[2024-06-10 05:13:34] info: 	z2m: Starting zigbee-herdsman (0.49.2)
[2024-06-10 05:13:34] info: 	zh:ember: Using default stack config.
[2024-06-10 05:13:34] info: 	zh:ember: ======== Ember Adapter Starting ========
[2024-06-10 05:13:34] info: 	zh:ember:ezsp: ======== EZSP starting ========
[2024-06-10 05:13:34] info: 	zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-06-10 05:13:34] info: 	zh:ember:uart:ash: Socket ready
[2024-06-10 05:13:34] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2024-06-10 05:13:37] info: 	zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-06-10 05:13:37] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2024-06-10 05:13:39] info: 	zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-06-10 05:13:39] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2024-06-10 05:13:42] info: 	zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-06-10 05:13:42] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2024-06-10 05:13:44] info: 	zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-06-10 05:13:44] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2024-06-10 05:13:47] error: 	z2m: Error while starting zigbee-herdsman
[2024-06-10 05:13:47] error: 	z2m: Failed to start zigbee
[2024-06-10 05:13:47] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-06-10 05:13:47] error: 	z2m: Exiting...
[2024-06-10 05:13:47] error: 	z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
    at EmberAdapter.initEzsp (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:850:19)
    at EmberAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:2683:24)
    at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:127:29)
    at Zigbee.start (/app/lib/zigbee.ts:62:27)
    at Controller.start (/app/lib/controller.ts:109:27)
    at start (/app/index.js:107:5)
I checked this link of course, but I’m lost…
I hope you can clarify the following error for me because I suppose this is the problem: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
Thank you very much
Did you flash Ember capable firmware on the Sonoff ZBBridge Pro ?
Hello Francis, my bad… what is this firmware?
I use Tasmota in version 12.2.0
Thank you
Zigbee firmware 7.4.x
I think the latest Zigbee firmware in th Tasmota repository is a 6.10.x, so you should use
serial:
    adapter: ezsp
I’m going to work, I’m analyzing the firmware tomorrow.
I can already say that this code does not solve the problem but probably, it is part of it. I will correct this.
serial:
    adapter: ezsp
Thank you, I will keep you informed!
Hello, should I use this version?
This is the most recent one I found.
Ah, the Pro is a Ti chipset
it is
serial:
    adapter: zstack
Great! It going! Thanks!
I have this error now, I guess the address I have to broach it is not correct.
Here is the log:
[2024-06-18 18:59:25] info: 	z2m: Logging to console, file (filename: log.log)
[2024-06-18 18:59:25] info: 	z2m: Starting Zigbee2MQTT version 1.38.0 (commit #fe048e6)
[2024-06-18 18:59:25] info: 	z2m: Starting zigbee-herdsman (0.49.2)
[2024-06-18 18:59:25] info: 	zh:zstack:znp: Opening TCP socket with 192.168.1.171:8888
[2024-06-18 18:59:26] info: 	zh:zstack:znp: Socket connected
[2024-06-18 18:59:26] info: 	zh:zstack:znp: Socket ready
[2024-06-18 18:59:26] info: 	zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-06-18 18:59:27] info: 	zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-06-18 19:01:19] info: 	zh:controller: Wrote coordinator backup to '/app/data/coordinator_backup.json'
[2024-06-18 19:01:21] info: 	z2m: zigbee-herdsman started (reset)
[2024-06-18 19:01:21] info: 	z2m: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20220219,"transportrev":2},"type":"zStack3x0"}'
[2024-06-18 19:01:21] info: 	z2m: Currently 0 devices are joined:
[2024-06-18 19:01:21] info: 	z2m: Zigbee: disabling joining new devices.
[2024-06-18 19:01:21] info: 	z2m:mqtt: Connecting to MQTT server at mqtt://core-mosquitto:1883
[2024-06-18 19:01:21] error: 	z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-18 19:01:21] error: 	z2m: MQTT failed to connect, exiting...
[2024-06-18 19:01:21] info: 	z2m: Stopping zigbee-herdsman...
[2024-06-18 19:01:22] error: 	z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-06-18 19:01:23] error: 	z2m:mqtt: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
I tried:
mqtt://172.17.0.3:1883
I have this in return:
[2024-06-18 19:36:53] info: 	z2m: Logging to console, file (filename: log.log)
[2024-06-18 19:36:53] info: 	z2m: Starting Zigbee2MQTT version 1.38.0 (commit #fe048e6)
[2024-06-18 19:36:53] info: 	z2m: Starting zigbee-herdsman (0.49.2)
[2024-06-18 19:36:53] info: 	zh:zstack:znp: Opening TCP socket with 192.168.1.171:8888
[2024-06-18 19:36:53] info: 	zh:zstack:znp: Socket connected
[2024-06-18 19:36:53] info: 	zh:zstack:znp: Socket ready
[2024-06-18 19:36:53] info: 	zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-06-18 19:36:54] info: 	zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-06-18 19:37:12] error: 	z2m: Error while starting zigbee-herdsman
[2024-06-18 19:37:12] error: 	z2m: Failed to start zigbee
[2024-06-18 19:37:12] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-06-18 19:37:12] error: 	z2m: Exiting...
[2024-06-18 19:37:12] error: 	z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:101:27)
Thank you very much!
Check how you configured the other hardware, and just use the same mqtt settings
In my homeassistant configuration.yaml, I already have a relay card that works with my mqtt broker.
I don’t see how to make the connection.
Here is the code I use.
# this example for version >= 2022.09
# example relay board SN is 100,then replace "relay0" with "relay100"
mqtt:
  switch:
    - unique_id: Dingtian-relay0-all
      name: "Dingtian-relay0 Switch0 All ON/OFF"
      command_topic: "/dingtian/relay6202/in/control"
      availability:
        - topic: "/dingtian/relay6202/out/lwt_availability"
          payload_available: "online"
          payload_not_available: "offline"
      payload_on: '{"type":"ON/OFF","idx":"1","status":"ON","time":"0","pass":"0"}
      {"type":"ON/OFF","idx":"2","status":"ON","time":"0","pass":"0"}'
      payload_off: '{"type":"ON/OFF","idx":"1","status":"OFF","time":"0","pass":"0"}
      {"type":"ON/OFF","idx":"2","status":"OFF","time":"0","pass":"0"}'
      optimistic: false
      qos: 0
      retain: false
# relay1~2
    - unique_id: Dingtian-relay0-r1
      state_topic: "/dingtian/relay6202/out/r1"
      command_topic: "/dingtian/relay6202/in/r1"
      availability:
      payload_on: "ON"
      payload_off: "OFF"
      state_on: "ON"
      state_off: "OFF"
      optimistic: false
      qos: 0
      retain: true
    - unique_id: Dingtian-relay0-r2
      state_topic: "/dingtian/relay6202/out/r2"
      command_topic: "/dingtian/relay6202/in/r2"
      availability:
      payload_on: "ON"
      payload_off: "OFF"
      state_on: "ON"
      state_off: "OFF"
      optimistic: false
      qos: 0
      retain: true
# input1~2
  binary_sensor:
    - unique_id: Dingtian-relay0-i1
      state_topic: "/dingtian/relay6202/out/i1"
      availability:
      payload_on: "ON"
      payload_off: "OFF"
      qos: 0
    - unique_id: Dingtian-relay0-i2
      state_topic: "/dingtian/relay6202/out/i2"
      availability:
      payload_on: "ON"
      payload_off: "OFF"
      qos: 0
So, on your Dingtian relay, how did you set the mqtt broker?
Indeed, I was able to find the exact address of the broker.
Here is what this correction gives:
[2024-06-19 04:17:14] info: 	z2m: Logging to console, file (filename: log.log)
[2024-06-19 04:17:14] info: 	z2m: Starting Zigbee2MQTT version 1.38.0 (commit #fe048e6)
[2024-06-19 04:17:14] info: 	z2m: Starting zigbee-herdsman (0.49.2)
[2024-06-19 04:17:14] info: 	zh:zstack:znp: Opening TCP socket with 192.168.1.171:8888
[2024-06-19 04:17:14] info: 	zh:zstack:znp: Socket connected
[2024-06-19 04:17:14] info: 	zh:zstack:znp: Socket ready
[2024-06-19 04:17:14] info: 	zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-06-19 04:17:15] info: 	zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-06-19 04:17:19] info: 	z2m: zigbee-herdsman started (resumed)
[2024-06-19 04:17:19] info: 	z2m: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20220219,"transportrev":2},"type":"zStack3x0"}'
[2024-06-19 04:17:19] info: 	z2m: Currently 0 devices are joined:
[2024-06-19 04:17:19] info: 	z2m: Zigbee: disabling joining new devices.
[2024-06-19 04:17:19] info: 	z2m:mqtt: Connecting to MQTT server at mqtt://192.168.1.55:1883
[2024-06-19 04:17:49] error: 	z2m:mqtt: MQTT error: connack timeout
[2024-06-19 04:17:49] error: 	z2m: MQTT failed to connect, exiting...
[2024-06-19 04:17:49] info: 	z2m: Stopping zigbee-herdsman...
[2024-06-19 04:18:20] error: 	z2m:mqtt: MQTT error: connack timeout
[2024-06-19 04:18:51] error: 	z2m:mqtt: MQTT error: connack timeout
[2024-06-19 04:19:22] error: 	z2m:mqtt: MQTT error: connack timeout
[2024-06-19 04:19:26] info: 	zh:controller: Wrote coordinator backup to '/app/data/coordinator_backup.json'
[2024-06-19 04:19:26] info: 	zh:zstack:znp: closing
[2024-06-19 04:19:26] info: 	z2m: Stopped zigbee-herdsman
/app/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:264
  var er = new ERR_STREAM_WRITE_AFTER_END();
Error: write after end
    at writeAfterEnd (/app/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:264:12)
    at DerivedLogger.Writable.write (/app/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:300:21)
    at DerivedLogger.log (/app/node_modules/winston/lib/winston/logger.js:252:14)
    at Logger.log (/app/lib/util/logger.ts:164:25)
    at Logger.info (/app/lib/util/logger.ts:177:14)
    at Znp.onPortClose (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:113:16)
    at Object.onceWrapper (node:events:632:26)
    at Socket.emit (node:events:529:35)
    at TCP.<anonymous> (node:net:350:12)
My user/password are good.
Thank you again!
Download mqtt explorer (mqtt-explorer.com) and see if you can connect.
Hello!
I already had the MQTT Explorer program. :slight_smile:
My user/password works.
192.168.1.55
    dingtian
        relay6202
  $SYS
    broker
    version = mosquitto version 2.0.18
    uptime = 811107 seconds
       clients
       load
       messages
       store
       subscriptions
       shared_subscriptions
       retained messages
       publish
       bytes
Hello, I continue my investigations, I remain on this error above.
Access to the mqtt broker works.
The user used is admin to do the tests.
[2024-06-22 20:49:50] error: 	z2m:mqtt: Not connected to MQTT server!
[2024-06-22 20:49:50] error: 	z2m:mqtt: Cannot send message: topic: 'zigbee2mqtt/bridge/state', payload: '{"state":"offline"}
Since I’m using containers, maybe the LAN isn’t passing between items.
How can I check this?
Thanks!
Hello, I need help. Please…
How do you connect with mqtt-explorer ?
Hello Francis!
With mqtt://192.168.1.55:1883
My configuration.yaml (zigbee2mqtt)
frontend: true
mqtt:
  server: mqtt://192.168.1.55:1883
  user: *****
  password: *****
serial:
  port: tcp://192.168.1.171:8888
  adapter: zstack
advanced:
  network_key:
    - 152
    - 57
    - 224
    - 63
    - 140
    - 156
    - 158
    - 21
    - 252
    - 36
    - 255
    - 77
    - 62
    - 67
    - 141
    - 198
  pan_id: 4038
  ext_pan_id:
    - 204
    - 169
    - 144
    - 92
    - 184
    - 180
    - 162
    - 152
  homeassistant_legacy_entity_attributes: false
  legacy_api: false
  legacy_availability_payload: false
device_options:
  legacy: false
Thank you!
Just want to emphasise this. My dongle is a P, not an E, so it required zstack. It took a good few Google searches to find this.
Old post, but seems identical to the error I’m getting.
My Sonoff dongle is the E V2 and was working fine on a separate Raspberry Pi to my HA.
I noticed in my HA dashboard that all my Zigbee devices were showing unavailable and, on investigating my Zigbee2MQTT install found that I was getting an error.
I tried to re-flash it with various (correct) firmware via the Sonoff online flasher and a python app. All were successful, so the dongle is not dead.
However, it still throws the same error. I then killed the docker container and reinstalled:
sudo docker run \
   --name zigbee2mqtt \
   --restart=unless-stopped \
   --device=/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_f835ab12a54bef11bd5ec2a079f42d1b-if00-port0:/dev/ttyACM0 \
   -p 8080:8080 \
   -v /opt/zigbee2mqtt/data:/app/data \
   -v /run/udev:/run/udev:ro \
   -e TZ=Europe/London \
   ghcr.io/koenkk/zigbee2mqtt
Starting Zigbee2MQTT without watchdog.
[2025-09-15 21:17:48] info: 	z2m: Logging to console, file (filename: log.log)
[2025-09-15 21:17:49] info: 	z2m: Starting Zigbee2MQTT version 2.6.1 (commit #e9889e5d20e8911550d5231bc0349567cc2bb9ce
[2025-09-15 21:17:49] info: 	z2m: Starting zigbee-herdsman (6.0.4)
[2025-09-15 21:17:49] info: 	zh:ember: Using default stack config.
[2025-09-15 21:17:49] info: 	zh:ember: ======== Ember Adapter Starting ========
[2025-09-15 21:17:49] info: 	zh:ember:ezsp: ======== EZSP starting ========
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash: ASH COUNTERS since last clear:
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   Total frames: RX=0, TX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   Cancelled   : RX=0, TX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   DATA frames : RX=0, TX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   DATA bytes  : RX=0, TX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   Retry frames: RX=0, TX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   ACK frames  : RX=0, TX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   NAK frames  : RX=0, TX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   nRdy frames : RX=0, TX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   CRC errors      : RX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   Comm errors     : RX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   Length < minimum: RX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   Length > maximum: RX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   Bad controls    : RX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   Bad lengths     : RX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   Bad ACK numbers : RX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   Out of buffers  : RX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   Retry dupes     : RX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   Out of sequence : RX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash:   ACK timeouts    : RX=0
[2025-09-15 21:17:49] info: 	zh:ember:uart:ash: ======== ASH stopped ========
[2025-09-15 21:17:49] error: 	zh:ember:uart:ash: Failed to init port with error Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_f835ab12a54bef11bd5ec2a079f42d1b-if00-port0
[2025-09-15 21:17:49] error: 	z2m: Error while starting zigbee-herdsman
[2025-09-15 21:17:49] error: 	z2m: Failed to start zigbee-herdsman
[2025-09-15 21:17:49] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-09-15 21:17:49] error: 	z2m: Exiting...
[2025-09-15 21:17:49] error: 	z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
    at EmberAdapter.initEzsp (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:665:19)
    at EmberAdapter.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1547:24)
    at Controller.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
    at Zigbee.start (/app/lib/zigbee.ts:67:27)
    at Controller.start (/app/lib/controller.ts:101:13)
    at start (/app/index.js:149:5)
As you can see, the error is still there.
I’ve also run this on different computers to rule out a fault on the PC itself.
So, unless there’s something else I can do, then am I right in concluding that the dongle has developed a fault?
Thanks,
Richie
