hi everybody,
I installed homeassistant on my ds213air following this guide:
https://home-assistant.io/getting-started/installation-synology/
after a little bit troubleshooting the hass-daemon starts with no errors.
but I’m unable to access the website. "safari is unable to open the site 192.168.20.9:8123
firewall port is open on synology.
here the log file:
16-11-05 11:06:53 homeassistant.core: Bus:Handling <Event service_registered[L]: service=turn_off, domain=homeassistant>
16-11-05 11:06:53 homeassistant.core: Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeassistant>
16-11-05 11:06:53 homeassistant.core: Bus:Handling <Event service_registered[L]: service=toggle, domain=homeassistant>
16-11-05 11:06:54 homeassistant.core: Bus:Handling <Event service_registered[L]: service=reload_core_config, domain=homeassistant>
16-11-05 11:06:54 homeassistant.core: Bus:Handling <Event service_registered[L]: service=create, domain=persistent_notification>
16-11-05 11:06:54 homeassistant.bootstrap: Home Assistant core initialized
16-11-05 11:06:54 homeassistant.core: Starting Home Assistant (2 threads)
16-11-05 11:06:54 homeassistant.core: Starting Home Assistant core loop
16-11-05 11:06:54 homeassistant.core: Bus:Handling <Event homeassistant_start[L]>
16-11-05 11:06:54 homeassistant.core: Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant>
16-11-05 11:06:54 homeassistant.core: Bus:Handling <Event service_registered[L]: service=restart, domain=homeassistant>
16-11-05 11:06:54 homeassistant.core: Timer:starting
I’m able to access the normal site from my nas.
thanks in advance
frank
