Instant Ink Countdown for Hp Printer Integration
I didn’t want to hijack @bar 's post for this, so I decided to share my progress as a project.
I use the HP Instant Ink service. As a ‘free’ user I get 15 pages per month and I wanted to be able to view how many pages I had left in a month. My printer is integrated with Home Assistant, as per this topic.
I’ve added a ‘Counter’ to my configuration.yaml: -
counter:
  printer:
    initial: 15
    step: 1
    minimum: 0
and then two automations. The first automation decreases the counter by 1, every time my printer-sensor acknowledges a page has been printed.
- id: printer_page_count
  alias: Printer Page Count
  initial_state: 'true'
  - platform: state
    entity_id: sensor.hp_printer_printer
  - service: counter.decrement
    entity_id: counter.printer
The second automation resets the counter to the initial value at 6am, on the 24th of each month, this is easily adjusted to the specific day of a plan by changing the number in the condition section.
- id: hp_instant_ink_per_month
  alias: HP Instant Ink per Month
    - platform: time
      at: '06:00:00'
  condition:
    - condition: template
      # Change the number here to get whatever day of the month you want.
      value_template: "{{ now().day == 24 }}"
  - service: counter.reset
Finally I’ve added the counter to the Markdown section of my printer Lovelace card with the following one liner: -
<ha-icon icon="mdi:counter"></ha-icon> - Instant Ink: **{{ states('counter.printer') }}** Pages
This is obviously very basic but I thought it might be useful for some and if people are using any of the plans that allow pages to be carried over each month, this could be a good place to post your code and help others (me :wink:) in the future.
Hi! I was looking for this specific post. Just written 15 days ago, cool!
Thank you for sharing your implementation. I am going to implement and test it. :grinning:
For me, the state trigger was triggering every time I restarted Home Assistant.
I’ve built off this to try a different approach.
First install the “Variable” integration in HACS
Then:
configuration.yaml
var:
  printer_pages_at_month_start:
    friendly_name: 'HP Printer Pages at month start'
    initial_value: 50
    sensors:
      pages_left:
        value_template: "{{ states('var.printer_pages_at_month_start')|int - states('sensor.hp_printer_printer')|int + 50 }}"
and then reset the variable at the end of each billing cycle
automations.yaml
    - platform: time
      at: '06:00:00'
  condition:
      value_template: "{{ now().day == 18 }}"
  - service: var.set
      entity_id: var.printer_pages_at_month_start
      value: "{{ states('sensor.hp_printer_printer')|int }}"
Soon I’ll add roll-over pages too. But this seems to work for now.
Thank you for posting this! Great work :+1:
thanks guys, just what I was looking for .
Ive gone with dawiebe apporach as I think i can use the variables feature elsewhere…
Im also concerned with “missing” counts …
Thanks guys
sensor.hp_printer_printer este sensor no lo tengo disponible, pero tengo “sensor.hp_officejet_pro_8710” pero no da esa información
info: ‘HP OfficeJet Pro 8710 [****1]’
serial: *****Z
state_message: ‘’
state_reason: null
command_set: >-
PCL3GUI,PCL3,PJL,Automatic,JPEG,PCLM,AppleRaster,PWGRaster,DW-PCL,802.11,802.3,DESKJET,DYN
uri_supported:
  • ‘ipp://192.168.1.***/ipp/print’
  • ‘ipps://192.168.1.***:443/ipp/print’
    friendly_name: HP OfficeJet Pro 8710
    icon: ‘mdi:printer’
me pueden ayudar
I was having a problem with this solution working. This is an edited post and I’ve included the solution for me, which was to use data_template: instead of data:. This seems to crop up quite regularly for me! :man_facepalming:t2:
  - platform: time
    at: '06:00:00'
  condition:
  - service: var.set
    data_template:
      value: "{{ states('sensor.hp_printer_printer') | int }}"
Inspired by the posts above, I made an implementation of Instant Ink which should cover the monthly allowance, rollover and over-print scenarios. It uses only native HA components: sensors, input_date, input_number, and an automation.
Edit: Updates are available below, for
  • The Automation that resets and rolls-over values on the anniversary day.
  • Template Sensors, to remove the dependency on the deprecated ‘entity_id’ attribute.
  • Another option to calculate the next month renewal date (useful in HASSOS).
Also note that if your renewal date is on the 29th, 30th, or 31st, of the month, the ‘Next Renewal Date’ calculation will go askew where the number of days in the next month is less than that date - Feel free to offer a fix! :slight_smile:
It all hangs off a page of XML that’s provided by the printer - which I suspect is used by HP for the same purpose - and is found at: http://[Printer IP]/DevMgmt/ProductUsageDyn.xml.
Diving into the configuration, I have base information in input_number and input_datetime objects, which allows them to be set using cards in the front end of Home Assistant:
# Inputs for the HP Ink Print Plan
input_number:
# The total number of pages that had been printed at the start of this period of the printing plan.
# Set by the automation - id: '1588925532080'; alias: HP Envy 5540 Page Reset.
  hp_envy_5540_pages_at_month_start:
    name: Printed Pages Total at month start
    min: 500
    max: 10000
    step: 1
    icon: mdi:printer
    mode: box
# The current monthly allowance number of pages
# Set manually in a front-end card
  hp_envy_5540_pages_monthly_allowance:
    name: Monthly Allowance Pages
    min: 15
    max: 300
    step: 5
    icon: mdi:printer
    mode: box
# The maximum number of rollover pages allowed
  hp_envy_5540_pages_rollover_monthly_max_allowance:
    name: Rollover Maximum Pages
    min: 0
    max: 600
    step: 5
    icon: mdi:printer
    mode: box
# The rollover allowance for this month
  hp_envy_5540_pages_rollover_allowance:
    name: Rollover Allowance Pages
    min: 0
    max: 600
    step: 5
    icon: mdi:printer
    mode: box
# The number of pages in each overprint block, when the Monthly Allowance plus Rollover are exceeded
  hp_envy_5540_pages_overprint_block_size:
    name: Over Print Block Size
    min: 0
    max: 100
    step: 5
    icon: mdi:printer
    mode: box
# The cost of each overprint block, as a decimal
  hp_envy_5540_pages_overprint_block_cost:
    name: Over Print Block Cost
    min: 0
    max: 50
    step: 0.05
    icon: mdi:currency-gbp
    mode: box
# The start date of this period of the print plan
input_datetime:
  hp_envy_5540_this_period_start_date:
    name: This Period Start Date
    has_date: true
    has_time: false
    icon: mdi:calendar
Here I have some sensors to detect the total number of pages printed (using the printer’s XML service), and the next period renewal date. Note that I have my sensors in a separate config file from configuration.yaml.
# Gets the HP Printer Total Pages Printed from the printer's web service
# Needs package, 'xml-twig-tools', to be installed in Raspbian
# Inspired by: https://community.home-assistant.io/t/command-line-sensor-with-a-value-template-struggling/125957/3
- platform: command_line
  name: "HP Envy 5540 Total Pages Printed"
  command: "xml_grep 'dd:TotalImpressions[@PEID=\"5082\"]' http://<Printer IP>/DevMgmt/ProductUsageDyn.xml --text_only"
  value_template: "{{ value }}"
# Gets the HP Ink Next Allowance Period Start Date, using the command line to do the calculation.
# The command line method is simpler for handling date arithmetic
  name: "HP Envy 5540 Next Renewal Date"
  command: "date -d '{{ states('input_datetime.hp_envy_5540_this_period_start_date') }} 1 month' +%Y-%m-%d"
Now come the sensors to detect the number of pages remaining in the various buckets.
Generally the calculations are along the lines of:
‘Number of pages printed at the start of the period’
plus ‘Number of pages of this month’s allowance’
[plus ‘Number of pages of this month’s rollover allowance’]
minus ‘Number of pages printed right now’
# Used to track days remaining of HP Ink Printer Pages period
# Needs to have the date sensors installed as per: https://www.home-assistant.io/integrations/time_date/
# Use of sensor.date forces a daily update
    hp_envy_5540_allowance_days_remaining:
      friendly_name: "Allowance Days Remaining"
      value_template: >-
         {{ ((as_timestamp(strptime(states('sensor.hp_envy_5540_next_renewal_date'), '%Y-%m-%d'))|int - as_timestamp(strptime(states('sensor.date'), '%Y-%m-%d'))|int ) / 86400)|int }}
# The number of allowance pages remaining for this period
# Calculated when each page is printed, and at the start of each new Instant Ink period
    hp_envy_5540_pages_allowance_remaining:
      friendly_name: "Allowance Pages Remaining"
      value_template: >-
        {% if states('input_number.hp_envy_5540_pages_at_month_start')|int + states('input_number.hp_envy_5540_pages_monthly_allowance')|int - states('sensor.hp_envy_5540_total_pages_printed')|int >= 0 %}
          {{ states('input_number.hp_envy_5540_pages_at_month_start')|int + states('input_number.hp_envy_5540_pages_monthly_allowance')|int - states('sensor.hp_envy_5540_total_pages_printed')|int }}
        {% else %}
          0
        {% endif %}
      entity_id: sensor.hp_envy_5540_total_pages_printed,input_datetime.hp_envy_5540_this_period_start_date
# The number of rollover pages remaining for this period.
# Calculated when each page is printed, when the Rollover Allowance is reset, and at the start of each new Instant Ink period
    hp_envy_5540_pages_rollover_remaining:
      friendly_name: "Rollover Pages Remaining"
      value_template: >-
        {% if states('input_number.hp_envy_5540_pages_at_month_start')|int + states('input_number.hp_envy_5540_pages_monthly_allowance')|int - states('sensor.hp_envy_5540_total_pages_printed')|int < 0 and states('input_number.hp_envy_5540_pages_at_month_start')|int + states('input_number.hp_envy_5540_pages_monthly_allowance')|int + states('input_number.hp_envy_5540_pages_rollover_allowance')|int - states('sensor.hp_envy_5540_total_pages_printed')|int >= 0 %}
          {{ states('input_number.hp_envy_5540_pages_at_month_start')|int + states('input_number.hp_envy_5540_pages_monthly_allowance')|int + states('input_number.hp_envy_5540_pages_rollover_allowance')|int - states('sensor.hp_envy_5540_total_pages_printed')|int }}
        {% elif states('input_number.hp_envy_5540_pages_at_month_start')|int + states('input_number.hp_envy_5540_pages_monthly_allowance')|int - states('sensor.hp_envy_5540_total_pages_printed')|int < 0 and states('input_number.hp_envy_5540_pages_at_month_start')|int + states('input_number.hp_envy_5540_pages_monthly_allowance')|int + states('input_number.hp_envy_5540_pages_rollover_allowance')|int -   states('sensor.hp_envy_5540_total_pages_printed')|int < 0 %}
            0
        {% elif 1==1 %}
          {{ states('input_number.hp_envy_5540_pages_rollover_allowance')|int }}
        {% endif %}
# The number pages printed over and above the Monthly Allowance plus the Rollover Allowance
    hp_envy_5540_pages_overprint:
      friendly_name: "Over Allowance Prints"
      value_template: >-
        {% if states('input_number.hp_envy_5540_pages_at_month_start')|int + states('input_number.hp_envy_5540_pages_monthly_allowance')|int + states('input_number.hp_envy_5540_pages_rollover_allowance')|int < states('sensor.hp_envy_5540_total_pages_printed')|int %}
          {{ states('sensor.hp_envy_5540_total_pages_printed')|int - states('input_number.hp_envy_5540_pages_rollover_allowance')|int - states('input_number.hp_envy_5540_pages_monthly_allowance')|int - states('input_number.hp_envy_5540_pages_at_month_start')|int }}
        {% else %}
            0
        {% endif %}
# The cost so far of the pages that have been printed over the Allowance plus Rollover
    hp_envy_5540_pages_overprint_cost:
      friendly_name: "Over Allowance Cost"
      value_template: >-
        {% if states('sensor.hp_envy_5540_pages_overprint')|int > 0 %}
          {{ (1 + (states('sensor.hp_envy_5540_pages_overprint')|int / states('input_number.hp_envy_5540_pages_overprint_block_size')|int)) | multiply( states('input_number.hp_envy_5540_pages_overprint_block_cost')|int)|int  }}
        {% else %}
            0
        {% endif %}
Finally, there’s an automation which runs at the start of each ink period, which here is the 3rd day of the month. This cannot be edited in the front end.
- id: '1582325531280'
  description: 'Sets: - Total number of pages printed at the start of the period -
    Start Date of this period (to store a date to calculate the next one) - Maximum
    Rollover Allowance value for this month - Rollover Remaining to new Maximum Rollover
    Allowance value for this month'
  - at: 00:00:00
    platform: time
  condition:
    value_template: '{{ now().day|int == states(''input_datetime.hp_envy_5540_this_period_start_date'')[-2:]|int }}'
  - service: input_number.set_value
    entity_id: input_number.hp_envy_5540_pages_at_month_start
    data_template:
      value: '{{ states(''sensor.hp_envy_5540_total_pages_printed'') }}'
  - service: input_datetime.set_datetime
    entity_id: input_datetime.hp_envy_5540_this_period_start_date
    data_template:
      date: '{{ states(''sensor.date'') }}'
    entity_id: input_number.hp_envy_5540_pages_rollover_allowance
    data_template:
      value: "{% if states('sensor.hp_envy_5540_pages_allowance_remaining')|int +\
        \ states('sensor.hp_envy_5540_pages_rollover_remaining')|int > states('input_number.hp_envy_5540_pages_rollover_monthly_max_allowance')|int\
        \ %}\n  {{ states('input_number.hp_envy_5540_pages_rollover_monthly_max_allowance')|int\
        \ }}\n{% else %}\n  {{ states('sensor.hp_envy_5540_pages_allowance_remaining')|int\
        \ + states('sensor.hp_envy_5540_pages_rollover_remaining')|int }}\n{% endif\
Earlier I mentioned a card that can be placed on the front end, and here it is:
cards:
  - entities:
      - entity: input_datetime.hp_envy_5540_this_period_start_date
      - entity: input_number.hp_envy_5540_pages_at_month_start
      - entity: input_number.hp_envy_5540_pages_monthly_allowance
      - entity: input_number.hp_envy_5540_pages_rollover_allowance
      - entity: input_number.hp_envy_5540_pages_overprint_block_size
      - entity: input_number.hp_envy_5540_pages_overprint_block_cost
    title: HP Envy 5540 Instant Ink Configuration
    type: entities
type: vertical-stack
And to display the current values…
cards:
  - entities:
      - entity: sensor.hp_envy_5540_allowance_days_remaining
      - entity: sensor.hp_envy_5540_pages_allowance_remaining
      - entity: sensor.hp_envy_5540_pages_rollover_remaining
      - entity: sensor.hp_envy_5540_pages_overprint
      - entity: sensor.hp_envy_5540_pages_overprint_cost
    title: HP Envy 5540 Instant Ink Status
    type: entities
So hopefully this will help some folks. :slight_smile:
Also hopefully there are no bugs or typos! :slight_smile:
      value_template: >-
      value_template: >-
        {% else %}
          0
        {% endif %}
      value_template: >-
            0
        {% elif 1==1 %}
        {% endif %}
      value_template: >-
        {% else %}
            0
        {% endif %}
      value_template: >-
        {% else %}
            0
        {% endif %}
Where to place this code, is it part of the sensor?
@EventuallyFixed Can you help with this question?
Yes, these are Template Sensors.
I have since made changes to the code above, to take account of the breaking change for Template Sensors, caused by the removal of the ‘entity_id’ attribute.
It means that the Template Sensors now look like this:
  sensors:
# Use of sensor.date ought to force a daily update, according to https://www.home-assistant.io/integrations/template/
      value_template: >-
# "{% (if states('input_datetime.hp_envy_5540_this_period_start_date') %}" is a workaround to set a listener)
      value_template: >-
        {% if states('input_datetime.hp_envy_5540_this_period_start_date') %}
          {% else %}
            0
          {% endif %}
        {% endif %}
      value_template: >-
            0
          {% elif 1==1 %}
          {% endif %}
        {% endif %}
      value_template: >-
          {% else %}
            0
          {% endif %}
        {% endif %}
      value_template: >-
        {% if states('input_datetime.hp_envy_5540_total_pages_printed') or states('input_datetime.hp_envy_5540_this_period_start_date') %}
          {% else %}
            0
          {% endif %}
        {% endif %}
      unit_of_measurement: '£'
hi,
i adapted your code to my printer (hp 6230) but i have problems with this sensor. as a result it returns me -145625 days.
how can i solve? what does your 86400 mean?
thanks
I’m glad that this has been of some some interest! :smile:
Since I can’t shadow you on your PC, it’s going to be quite hard to debug.
  • I don’t know exactly what is meant by ‘adapted’, so I suggest you revert back to the backup you took of your configuration files before you made the changes, then insert these changes as-they-are, and finally set the values in the configuration card, and the printer IP address in the ‘HP Envy 5540 Total Pages Printed’ sensor. At that point, it ought to work.
From here, all I can do is share my dashboard page, and tell you how the date portion works.
  • The “input_datetime.hp_envy_5540_this_period_start_date” is set manually: It should be set to the date that is your particular Start Date for the current period of Instant Ink. You can see this date at the top of the “HP Envy Instant Ink Configuration” card, on the right-hand side of my dashboard. Note that all of the values in this card must be set (except for Total Pages Printed, which is grabbed from the printer). You must also set the automation to the same day number of the month, so that the automation will update it on that day. (The automation has been updated - see below)
  • The ‘Next Renewal Date’ is set in the Command Line Sensor, “HP Envy 5540 Next Renewal Date”, and it depends on the ‘This Period Start Date’ above being set.
  • The piece of code you are referring to, is subtracting the UNIX Timestamp value of ‘Today’ from the UNIX Timestamp value of the ‘Next Renewal Date’. That answer is in units of seconds, so the division by 86,400 converts that answer into units of days (86,400 is, of course, the number of seconds in a day: 60seconds * 60minutes *24hours).
Because you have a large and negative answer for this, it suggests that the ‘This Period Start Date’ is either not set, or is set to a date that is way in the past. So what is it’s value?
Edit:
I have now improved the automation, so that it uses the day number of the ‘This Period Start Date’, instead of having to enter this day number in to two places. The automation now looks like this:
  - at: 00:00:00
    platform: time
  condition:
    data_template:
    data_template:
    data_template:
Text
hi @EventuallyFixed , thanks for the reply. I simply replaced 5540 with 6230 every time I found it and entered the ip of my printer.
but i have these errors
What is the value of your ‘input_datetime.hp_envy_5540_this_period_start_date’?
The “ input_datetime.hp_envy_5540_this_period_start_date ” is set manually: It should be set to the date that is your particular Start Date for the current period of Instant Ink. You can see this date at the top of the “ HP Envy Instant Ink Configuration ” card, on the right-hand side of my dashboard. Note that all of the values in this card must be set (except for Total Pages Printed, which is grabbed from the printer).
Screen grab what you have for this whole card (HP Envy Instant Ink Configuration) & attach, please.
What_Is_This_Set_To
Additionally, I see from your screenshot that ‘sensor.hp_envy_6320_total_pages_printed’ is set to Unknown.
  • Do you have a printer page at http://[ Printer IP ]/DevMgmt/ProductUsageDyn.xml? Without that page being available, the page tracking won’t work.
  • Did you set your Printer IP address in the ‘HP Envy 5540 Total Pages Printed ’ sensor?
  • Did you install the package, ‘xml_twig-tools’ in the underlying Operating System?
  • I guessed that the XML tag & attribute ‘dd:TotalImpressions[@PEID="5082"]’ held the total number of pages printed, and I was lucky enough to be correct. YMMV.
@EventuallyFixed here is the screenshot.
I tried to follow it step by step and I think the problem is on this sensor which gives me value 0.
  name: "HP Envy 6230 Next Renewal Date"
  command: "date -d '{{ states('input_datetime.hp_envy_6230_this_period_start_date') }} 1 month' +%Y-%m-%d"
the date sensor works fine, i think the problem is on the one mentioned earlier
yes, I have that page, I set the ip but it doesn’t read it to me.
oh,
I have not installed the package " xml_twig-tools "
but i think i can solve with the original integration sensor which works fine. I’ll just have to change part of the code
As per my code comments, that sensor is an OS Command, which works (for me) on Raspbian (linux). I’m pretty familiar with Linux, so I found it easier to do this, than to use Jinja. You may want to try that command in the OS, to check that it works.
An alternative option would be to use a Template Sensor instead. Something like this, which I have just thrown together and should work for where the day number is 1 to 28. Note that I have not tested this, other than to verify that a timestamp is produced from both possibilities of answer…
        {% if (states('input_datetime.hp_envy_5540_this_period_start_date').split("-")[1]|int + 1 > 12) %}
          {{ as_timestamp(strptime( (states('input_datetime.hp_envy_5540_this_period_start_date').split("-")[0]|int + 1)|string + "-01-" + states('input_datetime.hp_envy_5540_this_period_start_date').split("-")[2] , '%Y-%m-%d')) }}
        {% else %}
          {{ as_timestamp(strptime( states('input_datetime.hp_envy_5540_this_period_start_date').split("-")[0]|int|string + "-" + (states('input_datetime.hp_envy_5540_this_period_start_date').split("-")[1]|int + 1)|string + "-" + states('input_datetime.hp_envy_5540_this_period_start_date').split("-")[2] , '%Y-%m-%d' )) }}
        {% endif %}
@EventuallyFixed thank you for the help you are giving me.
I have tested your updated code but it does not give a valid result.
i am on hassos on raspberry4.
