Instant Ink Countdown for Hp Printer Integration
Hey, I’m currently trying to implement this, but unfortunately I’m running into a small problem that has to do with the code part:
  sensors:
I think the platform: template was removed.
I’ve already tried this with template and then sensors, but that doesn’t work either because I get corresponding messages in the logs.
Does anyone have a suggestion for a solution?
It is not removed. scrape sensor changed and i use multiscrape now.
Will update the the yaml to the new template standard aswell these day and place it here.
This is what i made from it, change all to the new template. Used available check (maybe overdone) removed the need of any scraple sensor and ping sensor.
You need to make this in one package file:
# /config/integrations/custom_packages/hp_printer/instant_ink_print_plan.yaml
# Inputs
# Inputs for the HP Ink Print Plan
input_number:
  # The total number of pages that had been printed at the start of this period of the printing plan
  # Set by an automation
  hp_printer_pages_printed_at_month_start:
    name: "HP Printer - Pages Printed at month start"
    min: 0
    max: 50000
    step: 1
    icon: mdi:printer
    mode: box
  # The current monthly allowance number of pages
  # SET THIS ONCE FOR THE INAUGURAL RUN, and after then it is set by an automation
  hp_printer_pages_monthly_available:
    name: "HP Printer - Monthly Pages Available in Plan"
    min: 15
    max: 500
    step: 1
    icon: mdi:printer
    mode: box
  # The number of pages that remain of the rollover allowance for this month
  hp_printer_pages_rollover_available:
    name: "HP Printer - Available Rollover Pages"
    min: 0
    max: 600
    step: 1
    icon: mdi:printer
    mode: box
  # The maximum number of rollover pages allowed.
  # SET THIS ACCORDING TO YOUR PLAN
  hp_printer_pages_rollover_monthly_max:
    name: "HP Printer - Monthly Maximum Rollover Pages"
    min: 0
    max: 600
    step: 1
    icon: mdi:printer
    mode: box
  # The number of pages in each overprint block, when
  # the Monthly Allowance plus Rollover are exceeded
  hp_printer_pages_overprint_block_size:
    name: "HP Printer - Over Print Block Size"
    min: 0
    max: 100
    step: 1
    icon: mdi:printer
    mode: box
  # The cost of each overprint block, in £
  hp_printer_pages_overprint_block_cost:
    name: "HP Printer - Over Print Block Cost"
    min: 0
    max: 50
    step: 0.01
    unit_of_measurement: "EUR"
    icon: mdi:currency-eur
    mode: box
  # The number of total available pages remaining to trigger a notification
  hp_printer_pages_total_remaining_notification:
    name: "HP Printer - Pages Notification"
    min: 1
    max: 1000
    step: 1
    icon: mdi:printer
    mode: box
# Input DateTime
input_datetime:
# The start date of this period of the print plan
  hp_printer_this_period_start_date:
    name: "HP Printer - This Period Start Date"
    has_date: true
    has_time: false
    icon: mdi:calendar
# Input Select
input_select:
  hp_printer_print_plan:
    name: "HP Printer - Print Plan"
    options:
      - Free
      - Paid
    initial: Paid
    icon: mdi:printer
# Template Sensor
template:
  # Energie DSMR Readings and Prices
  - sensor:
      # The number of standaard available pages remaining for this period
      # Calculated when each page is printed, and at the start of each new Instant Ink period
      - name: "HP Printer - Pages Available Remaining"
        unique_id: "hp_printer_pages_available_remaining"
        state: >
          {% if states('input_datetime.hp_printer_this_period_start_date') %}
            {% if states('input_number.hp_printer_pages_printed_at_month_start')|int + states('input_number.hp_printer_pages_monthly_available')|int - states('sensor.hp_printer_pages_total_printed')|int >= 0 %}
              {{ states('input_number.hp_printer_pages_printed_at_month_start')|int + states('input_number.hp_printer_pages_monthly_available')|int - states('sensor.hp_printer_pages_total_printed')|int }}
            {% else %}
              0
            {% endif %}
          {% endif %}
        availability: "{{ has_value('input_datetime.hp_printer_this_period_start_date') and has_value('input_number.hp_printer_pages_printed_at_month_start') and
        has_value('input_number.hp_printer_pages_monthly_available') and has_value('sensor.hp_printer_pages_total_printed') }}"
      # The number of rollover pages remaining for this period.
      # Calculated when each page is printed, when the Rollover Pages reset, and at the start of each new Instant Ink period
      - name: "HP Printer - Pages Rollover Remaining"
        unique_id: "hp_printer_pages_rollover_remaining"
        state: >
            {% if states('input_number.hp_printer_pages_printed_at_month_start')|int + states('input_number.hp_printer_pages_monthly_available')|int - states('sensor.hp_printer_pages_total_printed')|int < 0 and states('input_number.hp_printer_pages_printed_at_month_start')|int + states('input_number.hp_printer_pages_monthly_available')|int + states('input_number.hp_printer_pages_rollover_available')|int - states('sensor.hp_printer_pages_total_printed')|int >= 0 %}
              {{ states('input_number.hp_printer_pages_printed_at_month_start')|int + states('input_number.hp_printer_pages_monthly_available')|int + states('input_number.hp_printer_pages_rollover_available')|int - states('sensor.hp_printer_pages_total_printed')|int }}
            {% elif states('input_number.hp_printer_pages_printed_at_month_start')|int + states('input_number.hp_printer_pages_monthly_available')|int - states('sensor.hp_printer_pages_total_printed')|int < 0 and states('input_number.hp_printer_pages_printed_at_month_start')|int + states('input_number.hp_printer_pages_monthly_available')|int + states('input_number.hp_printer_pages_rollover_available')|int - states('sensor.hp_printer_pages_total_printed')|int < 0 %}
              0
            {% else %}
              {{ states('input_number.hp_printer_pages_rollover_available')|int }}
            {% endif %}
          {% endif %}
        has_value('input_number.hp_printer_pages_monthly_available') and has_value('sensor.hp_printer_pages_total_printed') and
        has_value ('input_number.hp_printer_pages_rollover_available') }}"
      # Total number of bundled plus rollover pages remainig for this period
      - name: "HP Printer - Pages Total Remaining"
        unique_id: "hp_printer_pages_total_remaining"
        state: "{{ states('sensor.hp_printer_pages_available_remaining')|int + states('sensor.hp_printer_pages_rollover_remaining')|int }}"
        availability: "{{ has_value('sensor.hp_printer_pages_available_remaining') and has_value('sensor.hp_printer_pages_rollover_remaining') }}"
      # The number pages printed over and above the Monthly Available plus the Rollover Available
      - name: "HP Printer - Pages Overprint"
        unique_id: "hp_printer_pages_overprint"
        state: >
            {% if states('input_number.hp_printer_pages_printed_at_month_start')|int + states('input_number.hp_printer_pages_monthly_available')|int + states('input_number.hp_printer_pages_rollover_available')|int < states('sensor.hp_printer_pages_total_printed')|int %}
              {{ states('sensor.hp_printer_pages_total_printed')|int - states('input_number.hp_printer_pages_rollover_available')|int - states('input_number.hp_printer_pages_monthly_available')|int - states('input_number.hp_printer_pages_printed_at_month_start')|int }}
            {% else %}
              0
            {% endif %}
          {% endif %}
        availability: "{{ has_value('input_datetime.hp_printer_this_period_start_date') and has_value ('input_number.hp_printer_pages_printed_at_month_start') and
        has_value('input_number.hp_printer_pages_monthly_available') and has_value('input_number.hp_printer_pages_rollover_available') and has_value('sensor.hp_printer_pages_total_printed') }}"
      # The cost so far of the pages that have been printed over the standard Available plus Rollover Available
      # CHANGE THE CURRENCY CODE AS APPROPRIATE
      - name: "HP Printer - Pages Overprint Cost"
        unique_id: "hp_printer_pages_overprint_cost"
        device_class: monetary
        state_class: total
        state: >
          {% if states('sensor.hp_printer_pages_total_printed') or states('input_datetime.hp_printer_this_period_start_date') %}
            {% if states('sensor.hp_printer_pages_overprint')|int == 0 %}
              0
            {% elif states('sensor.hp_printer_pages_overprint')|int > 0 and ( (states('sensor.hp_printer_pages_overprint')|int - 1) % states('input_number.hp_printer_pages_overprint_block_size')|int == 0 ) %}
              {{ (1 + ((states('sensor.hp_printer_pages_overprint')|int - 1) / states('input_number.hp_printer_pages_overprint_block_size')|int)) | multiply( states('input_number.hp_printer_pages_overprint_block_cost')|int)|int  }}
            {% else %}
            {% endif %}
          {% endif %}
        availability: "{{ has_value('sensor.hp_printer_pages_total_printed') and has_value('input_datetime.hp_printer_this_period_start_date') and
        has_value('sensor.hp_printer_pages_overprint') and has_value('input_number.hp_printer_pages_overprint_block_size') and has_value ('input_number.hp_printer_pages_overprint_block_cost') }}"
      # The number of pages remaining for this month in the chargeable Over Printed area
      - name: "HP Printer - Pages Overprint Remaining"
        unique_id: "hp_printer_pages_overprint_remaining"
        state: >
          {% if states('sensor.hp_printer_pages_overprint')|int == 0 or (states('sensor.hp_printer_pages_overprint')|int % states('input_number.hp_printer_pages_overprint_block_size')|int == 0) %}
            0
          {% else %}
            {{ states('input_number.hp_printer_pages_overprint_block_size')|int - (states('sensor.hp_printer_pages_overprint')|int % states('input_number.hp_printer_pages_overprint_block_size')|int) }}
          {% endif %}
        availability: "{{ has_value('sensor.hp_printer_pages_overprint') and has_value('input_number.hp_printer_pages_overprint_block_size') }}"
      # Next Renewal Date
      # WILL NOT WORK FOR 29th, 30th, 31st OF THE MONTH
      - name: "HP Printer - Next Renewal Date"
        unique_id: "hp_printer_next_renewal_date"
        state: >
          {% if (states('input_datetime.hp_printer_this_period_start_date').split("-")[1]|int + 1 > 12) %}
            {{ (states('input_datetime.hp_printer_this_period_start_date').split("-")[0]|int + 1)|string + "-01-" + states('input_datetime.hp_printer_this_period_start_date').split("-")[2] }}
          {% else %}
            {{ states('input_datetime.hp_printer_this_period_start_date').split("-")[0]|int|string + "-" +  ('%02d' % (states('input_datetime.hp_printer_this_period_start_date').split("-")[1]|int + 1)) + "-" + states('input_datetime.hp_printer_this_period_start_date').split("-")[2] }}
          {% endif %}
        availability: "{{ has_value('input_datetime.hp_printer_this_period_start_date') }}"
      # Used to track days remaining of HP Ink Printer Pages period
      # Needs to have the date sensors installed as per: https://www.home-assistant.io/integrations
      # Use of sensor.date ought to force a daily update, according to https://www.home-assistant.io/integrations/template/
      - name: "HP Printer - This Period Days Remaining"
        unique_id: "hp_printer_this_period_days_remaining"
        state: "{% set dt = states('sensor.hp_printer_next_renewal_date') | as_datetime or today_at() %} {{ (dt | as_local - today_at()).days }}"
        availability: "{{ has_value('sensor.hp_printer_next_renewal_date') }}"
      # Makes use of HP Printer integration: https://github.com/elad-bar/ha-hpprinter
      # Convert the total pages printed from sensor.hp_printer_printer to a useable value
      - name: "HP Printer - Pages Total Printed"
        unique_id: "hp_printer_pages_total_printed"
        state: "{{ states('sensor.hp_printer_printer')|int }}"
        availability: "{{ has_value('sensor.hp_printer_printer') }}"
## ONLY if you can not use the HP Printer integration: https://github.com/elad-bar/ha-hpprinter
## Updated to UI or use MultiScrape (Install via HACS)
##multiscrape:
##  - name: "HP Printer Scraper"
##    resource: "https://hp-officejet.local/DevMgmt/ProductUsageDyn.xml"
##    scan_interval: 60
##    verify_ssl: false
##    sensor:
##      - unique_id: hp_printer_pages_total_printed
##        name: "HP OfficeJet 8022 Total Pages Printed"
##        select: 'dd\:TotalImpressions[PEID="5082"]'
##        value_template: >-
##          {% if value == "" %}
##            0
##         {% else %}
##           {{ value }}
##         {% endif %}
# Binary Sensors
## Set via UI ##
## Ping the Printer ##
##binary_sensor:
##  - platform: ping
##    host: 192.168.20.21
##    name: "hp-officejet"
##    count: 2
##    scan_interval: 30
# Automations
automation:
  # Reset Pages at new Period
  - id: "printer_page_reset"
    alias: "Printer - Page Reset"
    description: >-
      Sets: - Total number of pages printed at the start of the period -
      Start Date of this period (to store a date to calculate the next one) - Maximum
      Rollover Allowance value for this month - Rollover Remaining to new Maximum Rollover
      Allowance value for this month - Rollover from overprint pages.
      - at: "00:00:00"
        platform: time
    condition:
      - condition: template
        value_template: "{{ now().day|int == states('input_datetime.hp_printer_this_period_start_date')[-2:]|int }}"
      - service: input_number.set_value
        entity_id: input_number.hp_printer_pages_rollover_available
        data_template:
          value:
            "{% if is_state('input_select.hp_printer_print_plan' , 'Free') %}
            {## -=-=-= Free Plans accrue rollovers only from the OverPrint counter =-=-=- ##}
            {% if states('sensor.hp_printer_pages_overprint_remaining')|int > 0 %}
            {## -=-=-= If the OverPrint is in use, both the standard and rollover pages have been exhausted =-=-=- ##}
            {{ states('sensor.hp_printer_pages_overprint_remaining')|int }}
            {% else %}
            {## -=-=-= If the OverPrint is not in use, then however many rollover pages that remain get carried over =-=-=- ##}
            {{ states('sensor.hp_printer_pages_rollover_remaining')|int }}
            {% endif %}
            {% else %}
            {## -=-=-= Paid Plans accrue rollovers from both Unused Standard Prints, and from the OverPrint counter =-=-=- ##}
            {% if states('sensor.hp_printer_pages_overprint')|int > 0 and (states('sensor.hp_printer_pages_overprint')|int % states('input_number.hp_printer_pages_overprint_block_size')|int) > 0 %}
            {% elif states('sensor.hp_printer_pages_total_remaining')|int > states('input_number.hp_printer_pages_rollover_monthly_max')|int %}
            {## -=-=-= The OverPrint is not in use, so the sum of the Unused Standard Pages plus the Unused Rollover get carried over, subject to the Max Rollover Allowance =-=-=- ##}
            {{ states('input_number.hp_printer_pages_rollover_monthly_max')|int }}
            {% else %}
            {{ states('sensor.hp_printer_pages_total_remaining')|int }}
            {% endif %}
            {% endif %}"
        entity_id: input_number.hp_printer_pages_printed_at_month_start
        data_template:
          value: "{{ states('sensor.hp_printer_pages_total_printed') }}"
      - service: input_datetime.set_datetime
        entity_id: input_datetime.hp_printer_this_period_start_date
        data_template:
          date: "{{ states('sensor.date') }}"
  # Alert when free pages are running low
  # Alert when overprinted
  - id: "printer_page_and_cost_notification"
    alias: "Printer - Pages and Costs Notification"
    description: >-
      Stuur een melding als de HP OfficeJet 8022 Free Pages count is lager dan de
      aangegeven waarde in de
      'input_number.hp_printer_pages_total_remaining_notification' entiteit, of als
      het aantal gratis paginas is overschreden.
        value_template: >-
          {% if
          states('sensor.hp_printer_pages_total_remaining')|int ==
          states('input_number.hp_printer_pages_total_remaining_notification')|int
          true
          {% endif %}
      - platform: state
        entity_id: sensor.hp_printer_pages_overprint_cost
        not_from:
          - "unknown"
          - "unavailable"
          - "Onbekend"
      - choose:
          - conditions:
              - condition: trigger
            sequence:
              - service: notify.rick_android
                  message: >-
                    Aantal Pagina's Resterend voor deze Maand is 10 of minder. Print
                    minder om extra kosten te verkomen.
                  title: "Printer - Minder dan 10 Pagina's resterend"
                    channel: "Printer"
                    clickAction: "/m-lovelace/info"
          - conditions:
              - condition: and
                conditions:
                  - condition: numeric_state
                    above: 0
            sequence:
              - service: notify.all_phones
                  title: "Printer - Aantal Maandelijkse pagina's Overschreden"
                  message: >-
                    Aantal Pagina's voor deze Maand is overschreden, huidige extra
                    kosten zijn € {{ states('sensor.hp_printer_pages_overprint_cost') }},-.
                    Nog {{ states('sensor.hp_printer_pages_overprint_remaining') }}
                    pagina's voordat er  weer € 1,- bijkomt. Print met mate.
                    channel: "Printer"
Remember to make use of the GitHub - elad-bar/ha-hpprinter: HP Printer Integration intergration via HACS
The current automation can also be done as a template trigger. But i am not capable of making that.
So if anyone is able to remove it as automation and make it a trigger template than go for it :stuck_out_tongue:
Template - Home Assistant (home-assistant.io)
" Trigger-based template binary sensors, buttons, images, numbers, selects and sensors"
I’ve been happy with my integration but recently purchased a new printer that doesnt appear to expose this endpoint/xml any more. (i.e http://IP/DevMgmt/ProductUsageDyn.xml)
UPDATE:
Since this solution relies on this single total_pages_printed, I was able to use a snmp sensor to retrieve me that number instead of the scraper above.
# Example configuration.yaml entry for SNMP version 3
hp_total_pages_printed:
  - platform: snmp
    host: yourprinter
    community: public
    baseoid: 1.3.6.1.4.1.14988.1.1.1.2.1.1 << or some other number
so instead of using the scraper I replaced it with this sensor.
To find the baseoid was bit tricky as there was no documentation, but what I did I used a snmpwalk command to list all the info the printer exposed
snmpwalk -Os -c public -v 1 192.168.0.197
which I copied the results into a text file
sysDescr.0 = STRING: HP ETHERNET MULTI-ENVIRONMENT	sysDescr.0 = STRING: HP ETHERNET MULTI-ENVIRONMENT
sysUpTimeInstance = Timeticks: (209217) 0:34:52.17	sysUpTimeInstance = Timeticks: (209761) 0:34:57.61
ifInOctets.1 = Counter32: 96244735	ifInOctets.1 = Counter32: 99276441
ifInOctets.3 = Counter32: 630551989	ifInOctets.3 = Counter32: 633761237
ifInUcastPkts.1 = Counter32: 1078193	ifInUcastPkts.1 = Counter32: 1090376
ifInUcastPkts.3 = Counter32: 2408404	ifInUcastPkts.3 = Counter32: 2421797
ifOutOctets.1 = Counter32: 96244735	ifOutOctets.1 = Counter32: 99276441
ifOutOctets.3 = Counter32: 27838391	ifOutOctets.3 = Counter32: 30596132
ifOutUcastPkts.1 = Counter32: 1078193	ifOutUcastPkts.1 = Counter32: 1090376
ifOutUcastPkts.3 = Counter32: 79187	ifOutUcastPkts.3 = Counter32: 86974
ipInReceives.0 = Counter32: 2440747	ipInReceives.0 = Counter32: 2463822
ipInUnknownProtos.0 = Counter32: 7397	ipInUnknownProtos.0 = Counter32: 7412
ipInDelivers.0 = Counter32: 2361050	ipInDelivers.0 = Counter32: 2383790
ipOutRequests.0 = Counter32: 1132116	ipOutRequests.0 = Counter32: 1151133
snmpInPkts.0 = Counter32: 4630	snmpInPkts.0 = Counter32: 9517
snmpOutPkts.0 = Counter32: 4630	snmpOutPkts.0 = Counter32: 9517
snmpInTotalReqVars.0 = Counter32: 4648	snmpInTotalReqVars.0 = Counter32: 9535
snmpInGetNexts.0 = Counter32: 4603	snmpInGetNexts.0 = Counter32: 9490
snmpOutGetResponses.0 = Counter32: 4654	snmpOutGetResponses.0 = Counter32: 9541
hrMemorySize.0 = INTEGER: 12584 KBytes	hrMemorySize.0 = INTEGER: 12784 KBytes
hrStorageUsed.1 = INTEGER: 300280	hrStorageUsed.1 = INTEGER: 300080
hrDeviceErrors.1 = Counter32: 13	hrDeviceErrors.1 = Counter32: 14
hrPrinterStatus.1 = INTEGER: other(1)	hrPrinterStatus.1 = INTEGER: idle(3)
mib-2.43.10.2.1.4.1.1 = INTEGER: 2	mib-2.43.10.2.1.4.1.1 = INTEGER: 3
mib-2.43.10.2.1.5.1.1 = INTEGER: 1	mib-2.43.10.2.1.5.1.1 = INTEGER: 2
mib-2.43.18.1.1.9.1 = Timeticks: (1594632712) 184 days, 13:32:07.12	mib-2.43.18.1.1.9.1 = Timeticks: (1777908712) 205 days, 18:38:07.12
and then, I printed pages and ran the command again, I saw only these two increased by one
with this I configured the value as below using a MIB Browser
1.3.6.1.2.1.43.10.2.1.4.1.1
Hope this helps someone else!
