Are there any bt/thread/zigbee/rf433 buttons then do not wait for doubleclick? I do not mean switches that simulate wall switch? That i solved with custom esphome hardware, but i want small button for the table or other places I need small-ish button. Ikea had those, but I experimented with ikea gateway, it paired the button by itself, updated it, and added doubleclick wait.
what does not have option to not wait for doubleclick:
aqara - about 800ms delay
aeotec - about 1 second delay
tuya whatever weird zigbee button - also tuya does not like non tuya gateways
ikea button 203.563.82
- after initial batch i’m afraid no way to keep fast response firmware - about 900ms delay
tuya wall switches (battery powered) - battery drain on non tuya gateway, does not react on press after some time of inactivity
what does not work at all:
switchbot remote - no BT advertising mode
So far best i found is the ikea 1/0 button 104.085.98
, that has pretty much instant reaction, but is not … cute … enough.
If i understand it correctly flick buttons would not work via esphome bt proxy, but they need flick hub?
I wonder if going lowtech with rf433 might actually be best in response time?
- https://www.aliexpress.com/item/4000510213912.html
- https://www.aliexpress.com/item/1005004995691777.html
- https://www.aliexpress.com/item/1005001993197399.html
- https://www.aliexpress.com/item/4000315760258.html
- https://www.aliexpress.com/item/1005005070440609.html
is there maybe some nicer alternaive to those?
Also for people thinking that zigbee is slow, this might be the root cause.
