Is ist possible to get a Instar Integration for IP Cams?
BR Tom
BR Tom
Instar is the name given to the developmental stage of an arthropod between moults. For example, after hatching from the egg and insect is said to be in its …
Perhaps a link, because the above is the meaning google gives.
Thanks. At a quick look, their wiki has lots of references to MQTT. Are you sure it isn’t compatible already?
Also
The Onvif Integration dont work because Instar 9408 2K+ use Digest Authentication by Onvif.
At the moment i had it working as HomeKit device in HA.
onvif appears to have digest auth, but I don’t have a device to test.
How is the mqtt stuff going?
Onvif integration doesnt work with this model.
Mqtt i have not tested.
I guess their website must be wrong then.
Oh man cool idea, does the motion alarm works this way? My instar 8001 is recognized my onvif butnthe alert entities are missing, this would help a lot
