Insteon - Adjusting Local On Level And Using Fast On/Off As Triggers
Hi there. I looked around for this and can’t seem to find it. I am trying to use Fast On/Off as triggers. But there is no option in the GUI. There is just plain old ON/OFF (see attached photo). I’m also trying to adjust the local on level of light switches programmaticlly. So at 10 pm, if I hit the light switch manual (like an animal) it will only go to 50%. Along all those lines, is there a list of all the things you can adjust with a switch?
Regarding Fast On/Off. This will be something you use in automations.
Here is an example of how to use it as trigger:
alias: "Kitchen - Turn On and Off All Lights in Kitchen "
description: "Turns on/off light when double pressing main switch "
  - platform: event
    event_type: isy994_control
    event_data:
      entity_id: light.main_light_k
      control: DFOF
  - platform: event
    event_data:
      control: DFON
condition: []
  - if:
      - condition: trigger
    then:
      - service: switch.turn_off
        data: {}
          entity_id: switch.indoor_outlet_11
      - service: light.turn_off
          entity_id: light.kitchen_lights
        data: {}
  - if:
    then:
      - service: switch.turn_on
        data: {}
      - service: light.turn_on
        data: {}
mode: single
Thank you! Three easy follow-up questions, if I may.
One, I see your event_type is for an ISY. Would this work for the direct Insteon integration (bypassing the ISY)?
Two, which is the part of the code that is specifcally addressing the actual press? I don’t know enough to parse it myself yet. Is it this?
control: DFON
And third, if it is, in fact the DFON snippet, do you know where I can find a master list of such things?
I lied. Four questions :slight_smile: And fourth, there is no way to do this in the GUI, right? It’s not that I just can’t find it? It has to be in YAML (for whatever reason, idk).
Thank you!
P.S. For anyone else stumbling along, I’m still looking for how to adjust the local on level of a switch, so when someone physically presses the button, the light can turn to a desired brightness (depending on the time of day).
Late to the party. But the Insteon integration can sent “on_fast_event” and “off_fast_event” which you should be able to capture with an event trigger.
I have not actually done this myself.
Regarding on level changes, I’m still looking for a solution.
